Bipolar PI design
Last update based on Carl's corrections (click to enlarge):
- Likes 1
I've moved the PI-GB discussion to a separate thread.
I have only just ordered a "final" PCB to build & test the bipolar design. You can wait for me to verify, or you can take the risk and start one yourself. I don't expect any major problems as I tested the design on a patched PCB and it was working fine. The only risk is if I missed any of the patch mods in the latest design.
The latest schematics, Gerbers, and code will always be posted in relevant ITMD3 forums. I will probably keep all revisions posted (assuming there are future changes) so that you can get any version you want.
C13 can be just about anything, 10n-100n is fine. It's just a noise filter for the pot.
C23 can be 10p-33p, or left out (as it is in the book schematic). It's also a noise filter (R13-C23), but you want it faster than R9-C14.
Q7 is NPN, 3904. Another book schematic error.
In the meantime you changed some components... some 100k resistors are now 47k, ok, I can't figure out which is the correct schematic now. Among other things; I need clarification on:
1) C13
2) C23
3) Q7 (3906 on schematic in the book, 3904 in recent schematics)
- Likes 1
Thanks, Carl, can you tell me what program the file was made with? I want to import the Gerber file. I assume the program will be able to do it.
It is a gap in the ground plane to isolate TX/digital ground noise from the RX.
- Likes 1
Hello, Carl, I want to ask you, what exactly is this path colored white here for it probably cuts off the back side, but isn't it still connected? Thank you.
I've just posted the schematic & PCB for the Bipolar PI design. I will post the source code as soon as I clean it up.
- Likes 1
To my pleasant surprise, I found a whole series of drivers at a local store: TC426, TC427, TC428 and TC429.
The prices are quite affordable.
Now it's a matter of pure tradeoff arguments between a couple of discrete mosfets and this kind of driver.
4 discrete mosfets in a SOT-23 package take up less space on the pcb.
(SOT-23 is something I still manage to solder to the pcb)
But the driver chips should work better.
- Likes 1
...thank you so much Sir Carl
