Bipolar PI design
  • boilcoil
    XC8?
  • algan
    Carl, what compiler are you using?Thanks.
  • Carl-NC
    I don't understand, file order does not matter. Just make sure they are all listed in the project.
  • algan
Name:	podredba na failove.jpg
ID:	435590 Hi, Carl, how should the BipolarPI source code be arranged? I do it like this, but it gives me an error that it cannot find common.h. I also tried manually specifying the folder. What advice would you give me? Thanks.
  • ivconic
    https://www.aliexpress.com/item/1005...Cquery_from%3A
  • GeoMax
    New toy, arrived yesterday:
    What model of USB oscilloscope is it?
  • ivconic
    Ah, that's a code-writing artifact that I haven't removed.
    I forgot it.
    The initial code had more functions.
    Now it has only 2 modes of operation: "Gen" and "Sweep".
    But the idea was to test the oscilloscope and not the generator.
  • Detectorist#1
    Zero percent's of what? The software some times gives slightly strange massages at first view.
  • ivconic
    While I wait for the pcbs to arrive...
  • ivconic
    I assume the "hiccup" on the oscillogram is due to the USB power supply.
    I didn't feel like checking because it's good enough as it is.
  • ivconic
  • ivconic
    For code readability I used Cpp directives.
    However, in the final version it is preferable to replace them with direct port&pin manipulation.
    Because the execution speed will be higher than 12x to even 40x !!!
    I plan to do that in the final version once everything else is checked and set up.
  • ivconic
    Ok, until I get the pcbs from JLPCB, no reason not to try porting the code.
    In the previous attempt, I did some things badly.
    Now I already have a working version.
    All that remains is to precisely set the time.
    The matter is more complicated because a potentiometer was also introduced to adjust the frequency.
    The code works. But it's still not tweaked to run the H-Bridge safely without risk.
    The main problem I have is the lack of a multi-channel oscilloscope (the 10k and pulse merging trick doesn't work very well, due to overlapping critical times).
    Currently, the frequency can be adjusted from 600Hz to 3kHz. But any change in frequency will affect the timing.
    (Perhaps introducing frequency change was a bad idea but it is a tempting challenge)
    It is recommended to test the code on the Arduino UNO platform without the rest of the hardware.
    Colleagues who have multi-channel oscilloscopes; can help a lot here!
    ​Click image for larger version
    Code:
     *  Bipolar PI metal detector by Carl Moreland
     * Ported from PIC16F18426 implementation
    #define TX_P_PIN      2   // Transmit positive pulse pin
    #define TX_N_PIN      3   // Transmit negative pulse pin
    #define CP_SYNC_PIN   4   // Charge pump sync pin
    #define TGT_P_PIN     5   // Target sample positive pin
    #define TGT_N_PIN     6   // Target sample negative pin
    #define GND_P_PIN     7   // Ground sample positive pin
    #define GND_N_PIN     8   // Ground sample negative pin
    #define POT1_PIN      A0  // Potentiometer 1 (delay) pin
    #define POT2_PIN      A1  // Potentiometer 2 (frequency) pin
    // Constants
    #define POT_AVE       8   // Number of samples to average for potentiometer readings
    #define POT_SHIFT     3   // Shift value for averaging (divide by 8)
    #define ON            HIGH
    #define OFF           LOW
    #define TRUE          1
    #define FALSE         0
    // Timing parameters (in microseconds, scaled by 8 in settings)
    struct AppSettings
      uint16_t txPeriod;  // TX pulse period (200-1000 μs)
      uint16_t txWidth;   // TX pulse width (50-200 μs)
      uint16_t tgtDelay;  // Target sample delay (10-30 μs)
      uint16_t tgtWidth;  // Target sample pulse width (20-60 μs)
      uint16_t gndDelay;  // Ground sample delay (5-20 μs)
      uint16_t gndWidth;  // Ground sample pulse width (20-60 μs)
    } settings;
    // Timing values calculated from settings
    struct TimingStruct
      uint16_t txWidth;
      uint16_t cpWidth;
      uint16_t txDelay;
      uint16_t tgtDelay;
      uint16_t tgtWidth;
      uint16_t gndDelay;
      uint16_t gndWidth;
    } timing;
    // ADC variables
    uint16_t pot1Array[POT_AVE];  // Running average array for pot1 (delay)
    int8_t pot1Index;             // Current index in pot1Array
    uint16_t pot1Total;           // Total of values in pot1Array
    uint8_t pot1Value;            // Current averaged pot1 value
    uint16_t pot2Array[POT_AVE];  // Running average array for pot2 (frequency)
    int8_t pot2Index;             // Current index in pot2Array
    uint16_t pot2Total;           // Total of values in pot2Array
    uint8_t pot2Value;            // Current averaged pot2 value
    // Interrupt state
    volatile uint8_t intState = 0;
    volatile uint8_t polarity = 1;
    // Function prototypes
    void initSettings();
    void initTimers();
    void updateTiming();
    bool adcRun();
    bool getPot1();
    bool getPot2();
    void clearSignals();
    // Timer1 Compare Match A ISR
    ISR(TIMER1_COMPA_vect)
      // Reset the counter
      TCNT1 = 0;
      switch(intState)
        case 0:  // Start of a new TX Pulse
          OCR1A = timing.txWidth;  // Set next compare for TX width
          if(polarity == 0)
            digitalWrite(TX_P_PIN, ON);  // Turn on P-side MOSFET
          else
            digitalWrite(TX_N_PIN, ON);  // Turn on N-side MOSFET
          intState++;
          break;
        case 1:  // Falling edge of the TX pulse
          OCR1A = timing.tgtDelay;  // Set next compare for target delay
          digitalWrite(TX_P_PIN, OFF);  // Turn off TX pins
          digitalWrite(TX_N_PIN, OFF);
          digitalWrite(CP_SYNC_PIN, ON);  // Toggle charge pump clock
          intState++;
          break;
        case 2:  // Start of Target sample
          OCR1A = timing.tgtWidth;  // Set next compare for target width
          if(polarity == 1)
            digitalWrite(TGT_P_PIN, ON);  // Turn on target sample
          else
            digitalWrite(TGT_N_PIN, ON);
          intState++;
          break;
        case 3:  // End of Target sample
          OCR1A = timing.gndDelay;  // Set next compare for ground delay
          digitalWrite(TGT_P_PIN, OFF);  // Turn off target sample pins
          digitalWrite(TGT_N_PIN, OFF);
          intState++;
          break;
        case 4:  // Start of Ground sample
          OCR1A = timing.gndWidth;  // Set next compare for ground width
          if(polarity == 1)
            digitalWrite(GND_P_PIN, ON);  // Turn on ground sample
          else
            digitalWrite(GND_N_PIN, ON);
          intState++;
          break;
        case 5:  // End of Ground sample
          OCR1A = timing.cpWidth;  // Set next compare for CP width
          digitalWrite(GND_P_PIN, OFF);  // Turn off ground sample pins
          digitalWrite(GND_N_PIN, OFF);
          intState++;
          break;
        case 6:  // Before next cycle
          OCR1A = timing.txDelay;  // Set next compare for TX delay
          digitalWrite(CP_SYNC_PIN, OFF);  // Toggle charge pump clock
          intState = 0;
          polarity = !polarity;  // Flip polarity for next cycle
          break;
    void setup()
      pinMode(TX_P_PIN, OUTPUT);
      pinMode(TX_N_PIN, OUTPUT);
      pinMode(CP_SYNC_PIN, OUTPUT);
      pinMode(TGT_P_PIN, OUTPUT);
      pinMode(TGT_N_PIN, OUTPUT);
      pinMode(GND_P_PIN, OUTPUT);
      pinMode(GND_N_PIN, OUTPUT);
      analogReference(DEFAULT);  // default 5V reference
      // Clear ADC signals
      clearSignals();
      // Initialize settings with default values
      initSettings();
      // Calculate initial timing values
      updateTiming();
      // Initialize timers
      initTimers();
    void loop()
      static bool adcFlag = false; // Single flag for ADC state
      if(intState == 1)
      { // Idle state
        if(!adcFlag)
          if(adcRun())    // Read pots and update if values changed
            updateTiming();
          adcFlag = true; // Mark ADC as checked
      else
        adcFlag = false;  // Reset flag when not in idle
    void initSettings()
      // Initialize timing settings (all in μs, scaled by 8)
      settings.txPeriod = 200 << 3;  // 200μs -> 5kHz
      settings.txWidth = 50 << 3;    // 50μs
      settings.tgtDelay = 15 << 3;   // 15μs
      settings.tgtWidth = 10 << 3;   // 10μs
      settings.gndDelay = 5 << 3;    // 5μs
      settings.gndWidth = 40 << 3;   // 40μs
    void initTimers()
      // Stop interrupts while setting up
      noInterrupts();
      // Setup Timer1 (16-bit timer)
      TCCR1A = 0;
      TCCR1B = 0;
      TCNT1 = 0;
      // Set compare match register
      // Turn on CTC mode
      TCCR1B |= (1 << WGM12);
      // Set CS10 bit for no prescaler
      TCCR1B |= (1 << CS10);
      // Enable timer compare interrupt
      TIMSK1 |= (1 << OCIE1A);
      // Re-enable interrupts
      interrupts();
    void updateTiming()
      uint16_t tmp;
      // Convert microsecond values to timer counts
      // Arduino runs at 16MHz, so each count is 0.0625μs (with no prescaler)
      // Multiply by 16 to convert microseconds to timer counts
      // Calculate TX pulse width
      timing.txWidth = (settings.txWidth >> 3) * 16;
      // Calculate target sample delay
      timing.tgtDelay = (settings.tgtDelay >> 3) * 16;
      // Calculate target sample width
      timing.tgtWidth = (settings.tgtWidth >> 3) * 16;
      // Calculate ground sample delay
      timing.gndDelay = (settings.gndDelay >> 3) * 16;
      // Calculate ground sample width
      timing.gndWidth = (settings.gndWidth >> 3) * 16;
      // Calculate charge pump width
      tmp = (settings.txPeriod + settings.txWidth) >> 1;
      tmp -= settings.tgtDelay + settings.tgtWidth + settings.gndDelay + settings.gndWidth;
      timing.cpWidth = (tmp >> 3) * 16;
      // Calculate delay to next TX pulse
      tmp = (settings.txPeriod - settings.txWidth) >> 1;
      timing.txDelay = (tmp >> 3) * 16;
    bool adcRun()
      if(getPot1() || getPot2())
        // Update settings with corrected scaling for tgtDelay
        settings.tgtDelay = (50 + pot1Value) << 3;  // Fixed: shifted by 3 instead of 1
        settings.txWidth = (50 + pot2Value) << 3;
        settings.txPeriod = (200 + (pot2Value << 2)) << 3;
        return TRUE;
      return FALSE;
    bool getPot1()
      uint16_t potValue;
      static uint8_t oldValue = 0;
      // Read and scale potentiometer value (0-1023 to 0-63)
      potValue = analogRead(POT1_PIN) >> 4;
      // Update running average
      pot1Total -= pot1Array[pot1Index];
      pot1Total += potValue;
      pot1Array[pot1Index] = potValue;
      // Increment index with wrap-around
      if(++pot1Index >= POT_AVE)
        pot1Index = 0;
      // Calculate average
      pot1Value = pot1Total >> POT_SHIFT;
      // Check if value changed
      if(pot1Value == oldValue)
        return FALSE;
      oldValue = pot1Value;
      return TRUE;
    bool getPot2()
      uint16_t potValue;
      // Read and scale potentiometer value (0-1023 to 0-255)
      potValue = analogRead(POT2_PIN) >> 2;
      pot2Total -= pot2Array[pot2Index];
      pot2Total += potValue;
      pot2Array[pot2Index] = potValue;
      if(++pot2Index >= POT_AVE)
        pot2Index = 0;
      pot2Value = pot2Total >> POT_SHIFT;
      if(pot2Value == oldValue)
        return FALSE;
      oldValue = pot2Value;
      return TRUE;
    void clearSignals()
      // Initialize the running average arrays for potentiometers
      pot1Index = 0;
      pot1Total = 0;
      for(int i = 0; i < POT_AVE; i++)
        pot1Array[i] = 0;
      pot2Index = 0;
      pot2Total = 0;
        pot2Array[i] = 0;
  • pechkata
    Thanks to Carl-NC everything is going well.
  • ivconic
    Of course it is a better choice!
    When something goes wrong; I have someone else to blame! (Carl)
