  • chuubaba
    ground is connected to potentiometers
    no no. this is '+E' potencial - for shielding, i call it 'COLD COIL END'.
    you have to connect your probe GND to '-E' or '-12V' point.
    T2 has AC current or DC?
    This is the wave form on 5mS/DIV 0.5V/DIV DC setting. Looks like the frequecy is 50Hzs. If I turn the PPS then frequency does not change. Click image for larger version
ID:	355323 If I adjust the PPS then the small dots near the wave form start moving fast or change movement direction.
    If i connect GND of the probe with -12V and take measurement then the wave form looks like this. Click image for larger version
    This is the wave form in X-Y mode. Click image for larger version
  • kt315
  • chuubaba
    good, but mistake.
    Tank you KT. I could not have corrected this mistake without you supervision. I have corrected this.
    Now i need to know Time and Volts settings for o-scope...
    I have set the probe to 10x and ground is connected to potentiometers and probe is inserted in T2.
  • kt315
    good, but mistake.
  • chuubaba
  • kt315
    chuubaba;262239]This test is performed without installation of MOSFET ?
    ye, without MOSFET. i write that 3 time. WITHOUT MOSFET.
    I found a 220v meter that has 56K Ohms resistor and a 1N4007 diode. Can this be used as a uA meter if i remove the resistor and the diode?
    probably yes. at first step do not connect it (to the pcb). it is not so important for work of DP.
  • chuubaba
    set 100Hz in point T2 - trimmer PPS. search the signal on o-scope.
  • kt315
  • chuubaba
    I have installed all components except tantalums.
    What is the next step?
  • kt315
    also, you have to clean every C and R pins BEFORE soldering in board.
    by a resin eraser that school children use everyday. on this pic best one.
    you clean 'grey/black' oxide layer that isolates the pin from soldering. if you do not want to do that you will get PROBLEMS.
    EVERY PIN BEFORE SOLDERING.
  • chuubaba
    why i must give same links again and again? litera A is 10V while i CLEAR wrote to use tantalums on 16V -
    you do not try to understand what i write. a laziness?
    I bought 10V for C42.
    Ok I see my mistake now. I am going to talk with seller about this.
  • kt315
    learn also especcialy made by me thread https://www.geotech1.com/forums/show...-on-boards-LOL!
    why i must give same links again and again? litera A is 10V while i CLEAR wrote to use tantalums on 16V (ie 20V is also good).
  • chuubaba
    sorry, i fogot to say. you set tantalums on last step.
    I haven't yet installed the Tantalum capacitors.
    This wire and paste i use.
  • kt315
  • kt315
    use https://en.wikipedia.org/wiki/Flux_(...ium_Loeten.jpg
    use standart ROSIN RESIN COLOPHONY. do not use exotic chinese flux.
