  • chuubaba
    You mean solder all components OR all transistors except MOSFET?
  • kt315
    solder all except MOSFET transistor.
  • chuubaba
    What is next step to build?
  • chuubaba
    The red LED is ON after voltage drops below 11.75V.
    I performed this test without installing NE555 and loudspeaker.
  • chuubaba
    Do I need to install NE555 for this test?
  • kt315
    turn on your power supply and change voltage from 11 to 12V. you must see how red color changes on green.
  • chuubaba
ID:	355303Ok. I have completed power regulator as shown in your picture. How to test this?
  • kt315
    not. this Click image for larger version
  • chuubaba
    I should wear plastic gloves before testing sound.
    Is this the voltage regulator part?
Name:	voltage regulator part.JPG
  • kt315
    yes remove the wire with resistor.
  • chuubaba
    Can i remove the killer resistor or it is required for further tests?
  • kt315
  • chuubaba
    This lesson about electrostatic i will not forget.
    What components make the voltage indicator part? Any pictures or videos?
  • kt315
  • kt315
