or diagnose what's causing the chip to burn.]
whats cause the chip to burn... you had learn hard lesson. no need to diagnose the cause.
ON YOUR BODY elementary accumulate electro-static field charge, UNVISIBLE charge. you go in your room, charge increases.
then you take naked wire with resistor... vu ala... charge discharged in way - your body ->
->wire-> electronics.
main rule from that. at first you must touch the GND potencial everywhere on pcb, then you can
follow your work.
Again i changed NE555 and now it is working. I dont want to test again because i fear burning the chip. Should i move to next step or diagnose what's causing the chip to burn. Resistor attached with coil wire is 10k.
I changed NE555. There was a small noise from speaker and then silence. I am using 12v power supply. Again it's not making sound.
good. you got a sound. try change NE555. do not use TLS555 and other JFETs timers.
rerun in especcially created by me thread https://www.geotech1.com/forums/show...ash-technology
C8 C9 C11 C19 C20 C23 C24
C14 C15
do not buy nothing. use components from trash boards. seek around old CRT vga svga monitors, tv, etc and take it.
all my projects use just trash technology, taking into account on poorest layers of people.
Ok i will use %0v Ceramic capacitors for C8, C9, C19, C24.Originally posted by kt315 View Post
Which other capacitors are located on power line ?
