  • Comment
    • Hi k315
      Please tell me what's these pin's
      T3
      T4
      T5
      T6
      T7
      E+
      E-
      • hi
        those pads are control points to tell main working principle of sch, a work of the sch, testing and fixing in case
        of a problem via o-scope.
        E+ and E- are points for checking of power supply and for connection of extental additional device pcb (LCD module of DP2, just for example), also other points too.
        • I Need help in testing and working thiis board. Made this from KT315 "MILAN KARAKAS" file.
          Both LED are ON and it makes very very faint sound. It is not detecting anything.
Name:	milan kraker.JPG
          • The single layer 'milan karakas" board is now working with the 28cm test coil. It has shown excellent discrimination with the test coil. Again lack of depth. Also i am unable to find what is the function of 220k variable and how to see it work on oscope.
            • Originally posted by chuubaba View Post
              [ATTACH]48216[/ATTACH]
              [ATTACH]48218[/ATTACH]
              you are crazy. do i have to reminder your answers to me????
              #764 practical guide you ask. waste a time to read it.
              #766 Don't give me trash.
              We will continue with gold tomorrow noon.
              #769 Have you seen the frequency used by him ??? This PDF can be gold for those building this brand and model for these settings but for DP REV5 it is trash. Why you misquote the work of right alien ??? You know very well about my level of skill and knowledge. It clearly says this is turkish board. turkish.JPG You disowned turkish board many times and refused to discuss about building and performance problems faced by members. But now you are giving me same design as guide for building DELTA PULSE REV 5 !!!
              and after those all you ask me about the (THE) turkish board???
              • This board is for experiments according to your recommendation about work of Iranian guy.
                Your DP REV5 is waiting for further instructions from your side. I have grounded the board by installing a insulated metal sheet under the board. There is no fancy enclosure yet.
                • Tests show that turkish board has better depth than DP REV5 despite use of some 5% resistors and clues from author.
                  • i set 5 10 and 20% resistors and what? because i MEASURE ALL resistors before soldering in board, you do not want.
                    if for you DP schematic is hardest so for me it's simplest. feel the difference.
                    • KT315 My DP REV5 cant detect a big metal 1'x1' (foot) beyond 1 meter in air. This is the best use 52cm diameter coil of 400uh 2.4R. Coil connecting cable is 3 meters hav7ng 3.2R. The board is in a metal enclosure grounded.
                      Why my board is not deep ?
                      • try turkish board now. you wrote turkish is better.
                          Turkish is performing best with 28cm coil.than your board so that project is complete for me.
                          It is your board that remains.
                          • you must get 110cm on pistol. i do not know what is your 'big metal 1'x1' (foot)'.
                            you do not show a video.
                            • Kt i requested you before not to talk about religious personalities. NOW I WARN YOU.
                              I don't want to discuss this md or anything else with you any more.
                                naked emotions again. nothing about DP, just again my personality touching - that all you are able to do.
