Shielding the pots will guard against electrostatic and electromagnetic fields affecting the internal pot tracks and by extension the circuit. Of course the front of the pots are shielded by metal chassis box which would also be grounded. Otherwise it makes no sense in plastic box. What do you think?
Wanted Please. Decant PI board to replace the One in This enclosure.
with P-channel mosfet connected to cold end of coil - to minus.(bara, surf)Originally posted by dbanner View PostYes, very good. Although the outer casing of pot is isolated from internals, they should be shielded I think, connected to virtual ground? Or battery? Not sure, will have to look at schematic.
in case N-channel mosfet connected to cold end of coil - to plus. (dp, hh)
THIS RULE IS SIMPLE TO REMEMBER.
Thanks for information KT. I am wobbly on shielding issues. Here is good document on the subject of shieldingAttached Files
So for Delta it is battery plus. And for surf and bara(p-channel MOSFET) it is battery minus. Good. No problem. ThanksOriginally posted by kt315 View Postwith P-channel mosfet connected to cold end of coil - to minus.(bara, surf)
Hi again guys.
could anyone point me in the right direction to buy a LF 357N Chip. i have been looking about the net/eBay for them. it looks like they all seem to come from china.
not very promising after after reading some of the post on the thread.
also replacing the 1N4148 diodes. do i change them with newly bought 1N4148 diodes. or replace them with 1N4004 diodes.
thanks in advance guys.
Hi again guys.
since this last post i have bought some LF 357N chips. here is some pics of the orignal one and the new ones.
when i took out the original chip. i had to pop it out and oops, some of the pins bent over and broke of f when i went to straighten then back up.
i tryied the new chips one at a time in the slot and the machine switches on but no sound/detecting etc out of it.
is the chips that i bougth the wrong numbers or something like that. i know they say LF 357N on them, but what about the other numbers etc on the chip what do they mean.
any advice on this one guys. it would be so much appreciated....
The first chip is definitely a fake. Lf357n is Texas instruments, national semiconductors, st electronics original. None of them look like your first chip. The second chips look like the real thing, but...... how can you be sure.
Did you check the diodes.
The chips you purchased purported to be national semiconductors brand, they look fake also. Here is authentic National semiconductors brand. Notice the difference.Attached Files
