Hello Bernd
Well, I had similar thought about it. Some controller and all other parts, I have already ordered.
But I thought to sell completed and tested boards with display too..maybe.
So I will think about, to sell pcb with soldered and programed controller.
The task of an adapter, I don't understand, because the controller can be easy better programed, soldered in place in the pcb.
For sale pcb Fortuna M2/M3 and M3
Yes absolutely for sure.Originally posted by Koala View Post[ATTACH]43186[/ATTACH]
Part of the enjoyment is in the build and tuning
Next enjoyment is in finding some that's a couple of thousand years old
But the final smile comes when you realise the artefact was found with a detector you built.
hi Fred,
in the case you would offer the boards with pre-programmed pic Controllers i would be interested in one set
but i have no experience in programming such small smd pic Controller
or do you offer a layout for a small Adapter pad from smd socket to through hole pin Header which fits to the pickit programmer?
Well, on the bottom side there are the most SMD parts, so your suggested methode make some sence but you need some special equipment I think,
so that your chicken will not be burned.
Anyway to complete the pcb in the way, like Koala suggested, you will only need solder paste, a tweezers and simple head magnifier. My solder point is with 0,8 mm, not very small.
The goal of any homemade detector, is in my opinion the fun to create your own stuff and of course to safe a lot of money.
With a proofed design of course, it is much more simple.
Also I think, SMT is faster than THT, you not need to turn your pcb so often. You can place all parts with the same value and solding them successively. Check all connections and place all parts with the next value...etc.
Yes indeed, oven reflow is the way to go with these boards.
Much like shake and bake chicken.
Yes, it's a breeze. No problem.
Seems like a lot of effort. Why not just by a good metal detector, already assembled? The logic behind assembling such devices one component at a time is no longer making sense in my opinion.
But I am respectful of designers efforts of the pcb, very nice work. Maybe there is a way to use oven reflow for one side at a time. I take it that both sides of board have components?
Yes I have similar good experiences with SMD
And I realy love to learn about, how to do different things, while watching youtube videos.
Here are some examples, which I use in the same or similar way.
How to make a double sided pcb at home:
How to make very flat vias:
How to solder SMD components:
How to desolder SMD components, works realy well with 0,2 mm copper wire:
I built a Bandido in SMT.Originally posted by dbanner View PostThe boards are very nice Indeed. The task of soldering all components individually looks very challenging. This is very nice project.
Seems scary. But turned out to be easier and cheaper than a through board build. I used solder paste. Small blob on each pad then the component place with tweezers. The paste acts like a glue to hold it in position. Quick touch of each end with the soldering iron and your done. No snipping leads.
Now also on Ebay. Description unfortunately only in german.
Well yes I think, now it is not so much of hard work, to complete the pcb and place all components.
Because could you imagine please, how difficult it is and how long time you need, to make a prototype pcb with the toner transfer methode on a double side pcb? After successful etching, comes the next step to connecting many many and more vias. I'm not sure, how many hours I was busy.
But of course, I like also this part of my hobbys.
But anyway I'm glad that I have done the prototype, because only in this way, I realized the problems which I had with Proteus.
Interesting for me to know would be, if someone else has noticed, that the software is doing some unwanted connections in converting the schematic to pcb? Or someone know, how to setup this program?
I already have looked lots of video tutorials in youtube and asked some people there about it, but nothing.
Thankyou.
Now the corn is growing in the field, in autumn I want to search again there and hope that something nice can be find there.
I was getting a copy of an old map from the archaeologist, there was an old grave mound still 150-200 years before. Now the surface is flat.
The boards look nice.
Your spear is in lovely condition. All the thousands of finds I have. I have nothing older than Roman.
