Originally posted by David_1
I tried TX coils with AWG 22 magnet wire and a fishing line spacer between the wires. It works, but the interwire capacitance and resistance is a little higher.
Using genuine Litz wire we could probably go with AWG 24 wire as it has significant lower resistance due to the Skin Effect.
Insulated, AWG 22, 1x19 tinned wire is a good compromise for TX.
Lower TX coil resistance reduces the RX offset.
Thicker wire is heavier.
The weight of the coil is an important ergonomic factor.
Like always a compromise has to be found.
http://www.miscel.dk/MiscEl/miscel.html This is the very useful calculator I use for most coil calculations.
