Just soldered together my Baracuda Legend (silverdog) kit and plugged it in but can't get it to work...
When I turn it on it gives a beep and the coil starts to buzz faintly but the speaker then goes quiet and no matter how i turn the pots I cant get any sound out of it, and no response when I bring any metal over the coil
- The coil is made of laquered copper wire, 22 turns at 27cm diameter. Gives about 2 ohms
- As a power source I am using a 9V alkaline batteri. When turned on it drops to 8.3volts
- I tried to replace the small piezo with a proper speaker, but works the same way
Any ideas on what to do? Wrong voltage? Don't think any of the components are backwards and all the soldering is neat and tidy
Building it was real easy but tuning it is a bit tricky...
