Baracuda Schematic
    [ATTACH]32174[/ATTACH]
    best resolution shematic i have for the moment
    just change the partnumbers if you find some parts which a not same on the actual layout
    thats not critical, follow the legs / pins of the integrated circuits and you will find what you want to know
    yea you ar true
    thanks bernte_one
      I have a question about the NE5534 schematic. The pcb layout from Apberg differs from the schematics, which is the right one?
      Leendert
        ALL info on bara http://www.geotech1.com/forums/showt...669#post200669
          Leendert
          this is the way and my way
          if the Schematic error Then you Still Follow The Schematic You Still Get Rong
          if The PCB Layout error Then You Still Folow The The PCB Layout You Still Rong
          what you need is try the Rong then try ask for help if in this forum, but if them want help!
          but if you have much money just buy the project
          Hahahah WTF Right
          ALL In This **** is About Money and conspiracy political
            i think this could be misunderstood
            the most project published here, are fully free and have good documention
            remind that most here hobby electronics, so some infos are not the best but we are here to improove thinks and our own skills
            so i a project have some little errors it is at your own to ask internet
            most shemes of power regulator or timers are same equal you have a audio amp or a metal detector
            my biggest failure in past was to dont read datasheets but you should
            70percent of my diy detectors run at first set up
            20percent later after i have corrected my own failures
            and 10percent never because of early stage of try and error
            but i often do new projects which are not 100% tested thats my own risk
              yea that is relly good and nice
                go to the Archive http://www.geotech1.com/forums/archi...x.php/f-8.html
                open fisrt point there. and you ll see your question for 2002 year. 2002 YEAR! the bara schematic has 2015-2002 = 13 years OLD.
                HA HA HA HA.
                  I will laugh with you whatsoever
                  HA HA HA HA HA
                    Well forget about that schematic. I came across it and kept it as it is easy to read but it seems it came from some scammer who publishes fake
                    schematics and laughs when someone tries to use it. Sorry for publishing it here I didn't look closely at it before linking it...
                      no need to say sorry Bro is not the big problem
                      the big problem is for nuebies like me
                      Hahahah
                        check on mistakes Click image for larger version
                          KT
                          Found a couple of mistakes. There may be others
                          Also the IRF9530 mosfet is only 100v. It should be IRF9630 or IRF9640 which are 200v
                            i got best results with tip127
                            baracuda has ability to pseudo discrimination if you turn delay down and threshold up you loose depth but it can detect an euro coin earlier the a iron bolt
                            also on the shematic sheet should be a list/ table of replacement components (mpf102 - bc256) or for 2n3819 ....
                            http://www.guitar-letter.de/Knowledg...eichsliste.htm
                            coil can also be smaller than 450µH, surf pi coil work also ok
                              fixed Click image for larger version
                                nice with thank KT315
