Barracuda Legend Kit Problems
  • Impulse
    here is the 1ms trace Click image for larger version
Name:	CH1 pin8 40106 CH2 40106 pin4 1ms.jpg
  • Impulse
    Originally posted by Old cart View Post
    Those look right, can you provide all images in a horizontal orientation? Also what is your battery voltage, and the voltage at the the plus and minus regulator 78/79l05's relative the shield?
    sorry i will correct the images as i go.
  • Impulse
    Can you repeat the last acquisition at 1 mS? This still looks wrong. Does the delay trimmer have any effect whatsoever on the relative positions of ch1 and ch2?
    Can you also show me the calibrator signal at 1mS per div on both channels?
    All 5? or the last one?
    also the delay trim has a slight affect in terms of amplitude not relative time or position
    and by calibrator signal you mean the scope signal?
    here Click image for larger version
Name:	Cal signal.jpg
  • Old cart
    Originally posted by Impulse View Post
    o and i have labled this picture so we are clear as this is what the data sheet says
    here [ATTACH]35370[/ATTACH]
  • Old cart
    heres the data for 40106 pin 8 - 12,2,6,4 the delay trim is set at 12.5 ohms
    here
    [ATTACH]35371[/ATTACH]
    [ATTACH]35372[/ATTACH]
    [ATTACH]35373[/ATTACH]
    [ATTACH]35374[/ATTACH]
    and the last one at 200us
    [ATTACH]35375[/ATTACH]
  • Impulse
    here
Name:	CH1 pin8 40106 CH2 40106 pin12.jpg
Name:	CH1 pin8 40106 CH2 40106 pin2.jpg
Name:	CH1 pin8 40106 CH2 40106 pin6.jpg
Name:	CH1 pin8 40106 CH2 40106 pin4.jpg
Name:	CH1 pin8 40106 CH2 40106 pin4 200us.jpg
  • Impulse
  • Impulse
    ok so trigger to ch2? as i cannot turn it off?
  • Old cart
    yes detector is working not great but is working
    1k - [ATTACH]35344[/ATTACH]
    Max - [ATTACH]35345[/ATTACH]
    OK, this still does not look right. Put delay at center rotation.
    Ch1 on 40106 pin 8 for all images, trigger off channel 1.
    Take the following 5 images, include ch1 and 2 in each image at 50uS
    pin 12, 2, 6, 4 then take one more shot of the last setting at 200 uS/ div.
    Unless the sampling is working properly nothing also will get you max depth.
  • raygdunn
    What headphones do you suggest guys?
    Hi Impulse,
    You might try the headset off your phone or tablet to start with.
    On tge Barracuda, I've wired my headset up as serial, so doubles the resistance rather than halves it. However everything I've tried has been too loud and is still a bit so after changing the audio 100 ohm for a 470. Headsets I've tested have given me 33-100 ohms for the pair. The in-ear ones were 33 ohms and loudest. Designed for lower power I expect.
    Ray
  • Impulse
    hey guys i have made a new coil (took ages) its a spiral wound 9.8" OD 27winds 313uH (as per online calculator) i am going to test it soon but the washing machine is going and it is upsetting the hole thing.
    heres a pic Click image for larger version
  • jladre
    here is the setup
    [ATTACH]35348[/ATTACH]
    [ATTACH]35349[/ATTACH]
    with nothing changed i have 4" clear signal, 5" almost and 6" slight
    Hi impulse! I suggest you to make another coil in order to optimized the barracuda power. Spiral wound, spider wave and 3dss coil is far more better. 8" - 10" diameter is good.
  • 6666
    Impulse after looking at your coil, what are the specs ?
  • Impulse
    i had one of these
    it worked to get the board going but was junk after that so i started using the buzzer which was better.
    What headphones do you suggest guys? as this is ultimately the route i want to take so if i buy some i would like to buy a 'good starter set/high impedance headphone set) which will also help with the barracuda build (difficult to get 'a' single 'best' i know) or just a speaker that you guys used/bought, where did ya get it? (32 ohm).
  • Old cart
    Don't know for sure but bet a speaker would be better, maybe much better. Try to get one that is 32 ohms like this
    high impedance headphones are an even better choice.
    Maybe others can comment about what works best.
