These are rather test coils, so not yet valid.
Both coils are wound with copper wire 0.5mm, the number of turns I do not remember.
10cm, 1.3 ohms, 206μH
16cm, 1.5 = ohms, 295μH
For the small coil, I have the winding split into layers, it makes me a better impression than the 16cm coil.
Baracuda broken
Would you mind telling what are your coil specifications thanks ?Originally posted by Andi68 View PostWith the scope I set the voltage exactly to 0V at Pin 6, Ne5534 and the sample delay with 16μs too small, VD 10 was broken.
And as I said, I was looking for the components, only today I tried a different setting without Scope
The circuit also works with C22 / 23- 470nF and C21-220nF
Replacement type for the 2N5485 = BF247
Now the world is alright for a short time
then time to do HH... you will see who from us is more angry my or Carl.
ahaha!
Jim Pugh mammy was the fault
Joking aside.
It was due to the setting, but I was looking for the error in the circuit
I am sure I have problems with the Bara, but other circuits worked immediately without any errors.
i fully agree with you Qia. bara is simplest PI with very evident schematic.
i read in RU forums that chinese are doing fake opamps. instead TL062 you can buy LM358 remarked. we are living
in the hard time of chinese lying.
If you're having problems with the Baracuda (which is a simple design) I would not recommend Hammerhead as your next project. You will be entering a new level of complexity.Originally posted by Andi68 View PostWell, first I want to get the Bara to work, no matter if I get help
or not.
I have time, annoyance brings nothing.
My next project could be the HH
