Arduino Nano VLF Metal Detector Project - Main Discussion
I can assure you that the build works perfectly as advertised.Originally posted by kosacid View Postok another batch of LT1054 there is something not right with this build who has actually got this build working ? there is a problem getting the negative voltage
To prove this, I have taken the attached measurements today.
1) PCB in case
2) Voltage at TP2
3) Voltage at TP3
4) Voltage at TP4
5) SYNC pulse
6) OSC pulse
The control box is quite large for a 3D printer. It would be much easier to buy an ABS plastic box from RS Components (Stock number: 1920756). The enclosure size is 60mm(H), 136mm(W), and 185.5mm(L).Originally posted by kosacid View Posthas anyone built a 3d box for this I'm lazy and need spoon fed, i don't mind building one but if someone has it would save me time lol
- Likes 1
so out of 10 chips i only got 2 working the OSC and Vref are broken or shorted i did further tests they are not fake chips just substandard when i tested them and used a external clock they work as you can see from the diagram, the working ones have saw tooth on the OSC and the Vref a steady half voltage on both them so there internal clock is working
- Likes 1
the descriptions didn't show the first one is the OSC next is Q1 base from the Arduino clock next is the output of the chip
- Likes 1
if you lift pin 7 you get negative voltage just under supply voltage, i breadboarded them but didn't test the OSC all worked fine, i got 2 that worked out of 20 chips3 Photos
- Likes 1
You can easily check if the sync pulse is getting to the LT1054s by connecting the scope to pin7 on either U2 or U3.Originally posted by kosacid View Postok i have traced it to Q1 i replaced it now i have - voltage after R18 the signal is low i was thinking the voltage is to low for it to switch the transistor how about instead of a 10K put say a 1K just to make sure its switching ?
The cheapest place to buy a second-hand coil is on eBay. The unbranded Chinese coil on page 128 is the cheapest new coil, again on eBay.Originally posted by kosacid View PostI'm up and running something no one has mentioned what's the cheapest coil I'm in the uk, I have it running on a garrett 150 coil is there any cheaper coils than that
The only problem with the Chinese coils is that they keep changing the model number. There's one on the UK eBay site at the moment for an MD6350 at £52.79, but it doesn't state the size.
Also, there's some knock-off copies of the Fisher F2 coils.
