Arduino Nano VLF Metal Detector Project - Main Discussion
I did have a problem with the footprint of c10 c30 c41 the last 2 are fine but I can't find caps to fit the footprint so they are sitting on top my question is there ones that fit that footprint?
These capacitors are fairly standard types with a 5mm pin spacing.
Here's an example from Farnell:
Need Help Building a Verified LT1054 Voltage Converter
Hi everyone,
I’m still really stuck trying to get my negative voltage rails working with the LT1054. I’ve replaced all the chips and checked everything, but I still can’t generate a stable negative supply.
Could someone please build and test just the voltage-converter portion for me on a board and verify it works? I’d be able to pay for your time and cover shipping if that’s possible.
Thanks so much!
- Ronin
What are you seeing on the scope at the collector of Q1?
Are you sure there is a sync pulse there?
Depending on the origin of some of these transistors they may have different pinouts than expected.
Hi everyone,
The arduino nano that I am using is not a offical one. Should I buy a offical one and test it with the circuit?
That shouldn't be a problem. The ones I have are clones from AZ-Delivery.
The output from the Arduino Nano should be +5V.
I assume your are using either an external power supply or battery pack, and not a USB supply connected to the Arduino?
Here is an update:
I have recived new LT1054 chips from a diffrent supplier, but unfortuantly that did not solve the problem.
I have wired the circuit standalone on a breadboard to see if my pcb was messed up, but that also did not solve the problem and the results are the same.
All of the components have been replaced at least once, and the sync pulse appears to be working when I check it through a oscilloscope.
I have tried Gunghouk's suggestion of temporarily removing the sync pulse, but that also did not change anything.
I am a little bit stumped at the moment.
Any tips would be appreciated.
That's very strange.
However, I can assure you that it definitely works.
One thing that strikes me as a bit odd is that you measured the +5V from the Arduino is only 4.72V.
