Tried Alternate Diff Coil (looks Striped - I call it my Tiger Coil) :
1: 60 foot length : Looped 1 Transmit 1mm wire , Looped 16 Receive 0.2mm Wires (total receive wire = 900ft).
2. Twisted all Wires at 1inch Intervals - 720 Twists with Drill.
3: Looped 15 times around 15inch Spoked Template.
4: Reconnected Receive wires in End-back-to-Start of next wire - like the Transmit-Receive wires.
-- Theory: - more Receive Winds will Multiply return Voltage.
Tested:
- Connected in place of old Diff-Transmit-Receive Coil
. . - ( Deffinately check that it is connected to circuitry correctly, Transmit Wattage will probably fry the receive wires if hooked up backwards ! )
=> Mixed Results - bigger Wave - very solid and clear , seemed to still shift with Targets.
=> Worked sometimes - unsure why yet (was late night - had limited time & concentration) - will try again when have more time.
jlsilicon
Tested:
jlsilicon
