PI CHIP
  • xix
    Challengeing approach. Wish you all success. You can find a lot of supporting info in whole moodz project here:
    http://www.geotech1.com/forums/forumdisplay.php?f=57
    KR,
    XiX
  • WM6
    Originally posted by xix View Post
    Thanks WM6.
    My idea was trying to use my old board with this new chip and for that I'd need to a different Port mapping on the software
    Cheers,
    XiX
    A differential front-end PI design originated by Moodz and open for community development.
  • xix
    You can try all with hex file which moodz very kindly (much than expected) share with us.
    You do not need source code to try it.
    Kind regards
    WM6
    Thanks WM6.
    Cheers,
    XiX
  • WM6
    ...... I'm considering to try it.
    Would be possible for you to share your source code?
    Kind regards
    WM6
  • xix
    Hex file of v23 for your continued enjoyment.
    [ATTACH]15907[/ATTACH]
    Hi Moodz,
    Congratulations! This approach dsPIC looks quite interesting and I'm considering to try it.
    In past I did some attempts with an old PIC but it was too slow to get relevant data.
    King regards,
    XiX
  • moodz
    Originally posted by authere View Post
    Hi Moodz,
    I have found that by getting the coil damping right it will increase the depth to which a nugget will be detected in air, what you have done is given it automatic adjustability, i think this will help no-end and should give us a few more nugg's per trip out.
    The fact that you can make most parts of a detector "Adjustable" in my book is the way to go, it's the only way we will find our ultimate detector and in most places we detect on the ground changes in form within 10-20 steps so an ever changing- rearranging detector seems the way to go.
    Like your work, Ron
    Thanks Ron ... It will probably be a pushbutton to "auto damp" the coil for fine target resolution.
    moodz.
  • moodz
    Moodz
    thanks for post #66 with the cut down surf cct
    this is good info on the pulse connections etc
    please keep up your great work
    Thanks 66 I will breadboard a practical circuit and publish.
    cheers and best regards,
    moodz.
  • authere
    Hi Moodz,
    Like your work, Ron
  • 6666
    Moodz
  • moodz
    Good news. Still not clear to me, if this "autodamp" is functioning literally as "auto", or we have some possibilities to control it at some degree from outside and adapt to certain soil situation?
    Ok I will put auto and manual in the menu .... . The auto is not perfected yet so it is manual anyway however surprisingly it is much smoother and less noiser than variable resistor solution.
    moodz
  • WM6
    I will also be looking to craft the algorithm so no matter what coil you hang off the machine it will "autodamp" .... no more resistor twiddling.
    moodz.
  • moodz
    active damping with servo tracking.
    The real fun begins with the addition of active damping to the differential front end ..... the coil damping can be set from the menu now. No longer dependant on a fixed resistance the optimal damping can be dialled up from the rotary control. ( I am tired of gassing myself with burning resistors in the workshop anyway )
    The servo tracking means that the damping can be autmatically adjusted on the fly as the coil inductance changes with changing ground conditions keeping the damping at some value.
    I am still testing this ....it is currently so good that the front end gain of the first amp can be run at 1000 and with a small coin giving over 1 volt of output signal. ( dont forget that the back end can resolve 40 microvolts ) So coupled with the backend and a big coil will still be sensitive to big targets.
    I will be testing the code some more before any releases ... also I need to determine exactly what active damping will mean since I dont have a commercial machine to to compare against.
    moodz.
  • mickstv
    Hi moodz, that package turned up today, thanks. The LCD and a few other components should come in on Mon or Tues, then I'll start final assy. The first version will be designed arround a MLab 10inch DD and Mono coils.
    Cheers
    Mick
  • mickstv
    Hi moodz, thanks for the update mate.
    cheers
    Mick
  • moodz
    UNIPI audio
    A very simple audio output can be had from the UNIPI chip with simply a series resistor of say 1000 ohms and a 16 ohm headset. Just connect directly to AUDIO out pin of UNIPI chip.
    Attached is an MP3 recording of audio output ..... clicking with no target .... frequency increases with target response..
    Enjoy.
    Moodz
    moodzpi_audio.zip
    PS ... the production line chip burner had a burnout so everyone who requested samples .... should be in the post Monday ... was Friday.
