gary's p1 circuit
HeIlo gays,
found that schematics and other information are available on the Thunting Forum in the download area.
@Phatom Ah yes, it would be helpful if I actually had looked at what you told me to. Many thanks that is just what I needed.
Cheers
@Phatom
Yes I have seen that schematic however I was referring to a complete one with the component values. Thanks.
Schematic is published in the post #6 of this thread, but it hasn't the values of the components.
Some years ago I remember that in Gary's WEB page was all the information, including photographs of the PCB and the schematic with the values
Now that Gary has passed away perhaps there are not problem to publish this information again. But, I can be wrong.
I would like to hear your opinions
Nevertheless, somewhere in the WEB I saw the complete schematic with values
Note: Also see #3 in:
It's too bad that the PI schematics did not get published.Originally posted by bernte_one View PostHi Gary, if you deside to end you electronic carreer could you please puplish all your shematics?
Originally posted by bernte_one View Posti think this was adressed to Andi68 and not to me
i care only for metal detectors
but if i plan to build a electro fencer i would take the magnetron and other parts from a microwave oven
That will be more like an electric chair
"bernte_one" A Car Coil Fencer puts out OVER 15KV and in a Very Fast Sharp Spike.
And an Insulator is effectively a Capacitor.
And this voltage Spike will travel right Though Many Insulators, Resulting in Shorting out the HV Wire.
The More Insulators and or the Greater the Total Capacitance, the Greater the Loss
If you look at the HV Wires going to the Spark Plugs on older cars, they are Suspended in Mid Air as Much as Possible, Because the Insulation on these wires is Totally Useless for this type of voltage.
Even two feet of this 100KV DC Test lead buried in Earth will Short out a car coil.
Took him awhile to get Good Insulators, but One Guy in Hawaii is using my fencer-2 to stop Wild Boar on a 1 KM long Fence and its working good.
Most Fencers put out a DC Pulse of Less than an 8KV which will Not Travel through Insulators.
Years ago I built the electric fence - it did not have any real strength
Originally posted by kt315 View PostPublish them to where?
in electronics for dummies
after building most Projects from first edt. it´s no fun, lot of things good complained but the Projects itself are a fail
too much what can go wrong
