I went to the electronics store and they didn't have the 40106 or the 74HC14, I've read that they are the same component with different names. I ordered it and I'll have it in a couple of days. I did buy the mosfet though, the one in the pdf is a irf9530, so I bought that one, At night I figured out you typed the wrong one because otherwise it wouldn't be an extra xD, I will post here what happens when I get the IC. I hope that solves the problem, thanks
Building the Geotech Barracuda Rev A (from silverdog)
I don't understand the part were you say " I've been meaning to ask Q why he changed it", I think you said that you tried to understand why he wrote 9640 instead of 9530? maybe he just mistyped, or was thinking on other project mosfet.Originally posted by 6666 View PostThe irf9530, is only a 100volt device, I've been meaning to ask Q why he changed it.
edit: Wait, by Q you meant Qiaozhi, you were wondering why he putted a 9530 instead of a 9640 in the schematic ?. In that case if I need another mosfet I can go to the electronics store when I go pick the 74hc14 and change it for other one, if Q thinks another mosfet would be more appropiate I'll change it
Hmmm ... that's a good question.Originally posted by 6666 View PostThe irf9530, is only a 100volt device, I've been meaning to ask Q why he changed it.
OK - I've looked at Apberg's Baracuda schematic, and it also shows an IRF9530. That's why I kept it the same.
However, it would be better if this was an IRF9640. I'll let Silverdog know, and he can change it in the next batch.
but this can limit the depth of the detector, if the flyback is limited to 100v. i don't remember how big the flyback goes. mine barracuda project have max depth of 20cm for a coin. i'm still waiting to get the power pot to find the best dumping resistor/.
The MOSFET will stay in avalanche longer with a lower breakdown voltage, and will slightly increase the minimum sampling time. However, the Baracuda is not designed for early sampling, so the the effect of replacing the MOSFET will be minimal in practice.Originally posted by ionut_mtb View Postbut this can limit the depth of the detector, if the flyback is limited to 100v. i don't remember how big the flyback goes. mine barracuda project have max depth of 20cm for a coin. i'm still waiting to get the power pot to find the best dumping resistor/.
You don't need a power pot to determine the best value of damping resistor. I've been using a ordinary pot in the damping resistor tool for a long time without any problems.
thanks for the reply, i've tested with ordinary pot, now max distance for average coin is 30cm (very faint signal), 20cm good signal. now better coil and oscilloscope is the key.Originally posted by Qiaozhi View PostThe MOSFET will stay in avalanche longer with a lower breakdown voltage, and will slightly increase the minimum sampling time. However, the Baracuda is not designed for early sampling, so the the effect of replacing the MOSFET will be minimal in practice.
Hi, I've replaced the 40106 and I tested with U.S coins, pretty much the same result.
Dime-> 3cm
5 cents -> 1cm (wow...)
Quarter -> 7-8cm
One cent -> 3-4cm
2€ -> 2cm
50 € cent -> 3cm
Small but strong magnet-> 40cm faint signal, 30cm strong signal
It doesn't matter what I do with the delay or minimum delay, same results, or maybe almost the same, I'm not very good at measuring.
Should I replace the mosfet too?
you need an oscilloscope! i think your problem is not the coil, not the dumping. i think is the delay. check values for next resistors to be the same like in schematic: r10,r11,r12, r15,r17,r21. how many cm you get for a coke can? and how many you get for something bigger?Originally posted by azigta View PostI have replaced the mosfet, same results
