Threshold Pot doesn't work
  • Carl-NC
    Are you using a mono coil?
  • h9361
    Pin 2 goes to ground, not -5V.
    Hello Dear Carl
    As promised, i finished the DISC demod and captured a video on scope during moving a Iron hammer over DD-coil.
    Frist i adjust sampling as follows:
    Click image for larger version  Name:	tpsam.jpg Views:	0 Size:	138.3 KB ID:	443754
    Then i connected both preamp and Disc demod to scope
    Click image for larger version  Name:	Iron.jpg Views:	0 Size:	137.5 KB ID:	443755
    After that, i captured a video from scope with measured parameters during moving an Iron hammer. You can watch from the link:
    https://drive.google.com/file/d/1PfH...ew?usp=sharing
    I have a request, please see following picture.
    Can you guide me, what schematic ( i remember that you told me that it can be a simple amplifier with gain pot as Iron sensitive pot) do you suggest me to add between the demod and 2n3904 for blanking audio ( inside the box)?
    Thank you.
    Click image for larger version  Name:	demod.png Views:	0 Size:	651.6 KB ID:	443756
  • h9361
    Thank you.
  • Carl-NC
  • h9361
    Always read the data sheet. The 74221 has 2 trigger inputs, A and B:
    The 555 pulse is fed to the B input (pin 2); when it goes high (to turn off the TX) the 74221 is triggered. What you want is to trigger the 74221 on the falling edge of the 555 (which turns on the TX). You will have to feed the 555 signal to the A input (pin1) instead, and then tie the B input to the high side (ground in this case).
    Thank you.
    I think your means is this,
  • Carl-NC
  • h9361
    That looks better.
    Dear Carl
    My friend is programing for adding TX sampling.
    But i want to test by 74hc221 until his work is finished.
    Please see attached, i tested the schematic, but the sample pulse can not locate on TX ( Can't go back any further).
    I changed C15 by 1n, 100P and 10P and R29 by 100R. No result.
    Do you have any suggestion for adjusting the sample pulse to TX?
  • Carl-NC
    That looks better.
  • h9361
    It looks like U3a is railed out, I have no idea why. Show the waveform at TP2.
    Thank you dear Carl.
    I checked again and found my mistake, TX was not worked. I fixed it.
    TP8 and TP9 as follows:
  • Carl-NC
  • h9361
    Either one will work.
    Hello
    Dear Carl
    Today, i built TX and preamp part based on the following :
    Click image for larger version  Name:	tx.jpg Views:	0 Size:	47.5 KB ID:	443570
    For first testing in my preamp output, i tested it with mono coil (500uH+680R)​.
    Form of my Tp8 is as
    Click image for larger version  Name:	Tp5.jpg Views:	0 Size:	112.2 KB ID:	443571
    And my Tp9 is as
    Click image for larger version  Name:	Tp4.jpg Views:	0 Size:	105.3 KB ID:	443572
    I think my TP8 and TP9 is not correct because its pulse is showing only receiving pulse and (it is very long).
    Do you have any suggestion for checking?
    Do you think i should reverse invert/non-invert of 5532 (pin 2 and 3)?
  • h9361
    Thank you. I will measure output voltage of DISC and will try to capture a video from ferrous/non-ferrous.
    So, you will see better and help me how to figure out its final amplifier stage for blank audio.
    Thank you dear carl for all supporting and your posts.
  • Carl-NC
  • h9361
    I have no idea what kind of amplifier you need or how much gain or anything else. You really need to build the extra demod stage and see what the "iron signal" looks like before you try to figure out what to do with it. I'm pretty sure you will not be able to design a complete circuit, build it, and have it work on the first try. Build it a little at a time, and figure out the next steps as you go.
    Actually, i have doubt about connecting TP8 or TP9 to my DISC demod.
    For better understanding (before making PCB), i simulated it with a pulse input (initial (low) voltage 0V and pulsed (high) voltage 5v).
    You can see my pulse setting as follow:
    Click image for larger version  Name:	pulseset.jpg Views:	0 Size:	50.7 KB ID:	443132
    The simulated schematic is as following:
    Click image for larger version  Name:	sim.jpg Views:	0 Size:	172.3 KB ID:	443130
    And the its scope is as follow:
    Click image for larger version  Name:	scop1.jpg Views:	0 Size:	101.5 KB ID:	443131
    If i change my pulse as initial (low) voltage -5V and pulsed (high) voltage 0v, Scope output will be as follow:
    According to the result and form of TP8 and TP9 (positive and negative preamp out), do you think which of TP8 or TP9 should be connected as input to DISC channel and sample it?
  • h9361
    OK. First i will build DISC part and measure its output when it detects IRON.
    I will notify here, then i hope you can help me for adding the amplifier stage with sensitivity control.
    I also simulated TX + preamp part on software. You can see its output on scope as following :
    Channel A ( yellow) is pulse generation (0 / -5V).
    Channel B (Blue) is TP8 on schematic #526.
    Channel D (Green) is TP9 on schematic #526.
    Do you think it is correct TP8 and TP9?
