R23 Problem
  • R23 Problem
    Hey Carl, I can't seem to zero out pins 2 and 3 of ic8. Everything up to this point has been ok. Any clues as to this. What should I look for. I think all my values are right. I'm following your directions but am clueless. Voltage across 2 and 3 is 2.15 and adjusting r23 changes absolutly nothing. I can adjust r18 to zero out tp4 but nothing with r23. I'm a newbie. Thanks again.
    Sorry v across pins 1and2 is 0v and can 't be varied by R23 v at pin 2 of ic8 is 2.15v and the same on pin 3.
      Hello
      Dear sir.
      I have built me second HH1, but i unfortunately have a problem with R23, exactly like you.
      I don't know why the trimmer has not any affect over pin 2,3 of IC-8. Is anyone to guide me?
        who told you that R23 is a nulling/balance of IC8????
          Originally posted by h9361 View Post
          Hello
          Dear sir.
          See this Post from Reg regarding this issue.
          A basic PI design with all parameters variable, intended as a learning platform for pulse induction.
            https://www.geotech1.com/forums/show...8477#post68477
            Thanks dear surfdetector.
            I have a question about the R23. Do you think R23 can affect over my poor detection? for example, coin from 1 cm!!!
            Have you tested sensitivity of your Hammerhead?
              Probably not. You need to start with the TX circuit and systematically probe the signals in your circuit. START A NEW THREAD and post pictures of your signals. Then maybe we can help. Right now you are asking us to guess your problem and people are getting frustrated with the endless questions that are posted all over the place.
