Powerful PI or Hammer Head (how to increase power of coil?)
  • #31
    hh
    Originally posted by nick_f View Post
    Rajesh, do you have an oscilloscope? How do you know TP7 fluctuates? TP7 should be identical with TP6, just a bit later in time. That pin should give very clean pulses and it is a simple circuit, almost identical with the circuit that provides signal at TP6. Compare the signals or voltage levels at pins of IC11 with IC12, they should be identical.
    Also, the voltages of Q8 and Q9 should be the same.
    Nicolae
    hi nick i have no that only multymeter digital can you tel me vallue of resister that will be fit ic5 pin number 3 to ground....
    • #32
      Hi rajesh, download miscel is a program that helps
      • #33
        hh
        hi vasster very thank's good link provide you.....
        • #34
          to NERDS
          Hi Rajesh,
          A large diameter coil will be less sensitive to smaller targets, but it should detect the large targets at a larger distance than a smaller coil.
          To increase the sensitivity of large coils, Tinkerer has a suggestion, to use a concentric coil. The smaller coil would be the receiver coil and for the same inductance, it will have more turns than the outer (transmitter) coil.
          Nicolae
          Rajesh where are u digging , do u have nice points to dig, use the modified circuit from the twin loop tresure seeker , use 2 coils one for Rx one for Tx, separte the powers lines. use lrge Tx coil......goes down to 2 feet for a 2 feet by one feet copper buried object,
          • #35
            hi i don't understand what are you saying. can you send me some link. treasure seeker is a tow box type locator. i have done hammerhead this working at least fine below a dete-1) Thumb pin
            Approx. 10 cm
            2) Cartridge
            Approx. 30 cm1) Thumb pin
            Approx. 10 cm
            2) Cartridge
            Approx. 30 cm
            3) Large 1 Rupee Coin
            Approx. 30 cm
            4) Bear can
            Approx. 50 cm
            5) Hand Grenade
            Approx. 90 cm
            6) Anti-tank mine (large metal)
            Approx. 150 cm
            Approx. 30 cm
            4) Bear can
            Approx. 50 cm
            5) Hand Grenade
            Approx. 90 cm
            Approx. 150 cm
            ction range...rajesh
            • #36
              hh
              Nicolae
              hi nick there are a countiniue tick -tick sound in speakar when i adjust r 18 it goes to down but sensitivity has loose
              • #37
                What IC are you using for IC6? Are you using NE5534? I checked a few different types and NE5534 gave me the best results.
                Did you adjust R18 while measuring voltage between ground and TP4? It should be zero volts when no target is near the coil. Also, R23 should be about to the middle position.
                Nicolae
                • #38
                  Nicolae
                  hi nick ic 6 is TL081. all measuring is fit. tp7 is some fluctuate but no problem from here. there are problem in audio section. i don't understand what's doing ic7 > C < i think pulse coming from there. when i replace [r 35] 5k to 10k sound goes to down but contiusly tick tick. when i short switch 2 sound goes to off few second.
                  • #39
                    amateur
                    On my hammerhead Power consuption is 100mA, is it right ? I have made mono coil with lan cable : diameter 35 cm, 24 turns, my damping resistor is 1k ohm. I have good results on the air , I have not try outside.
                    • #40
                      That sounds about right, I remember 80mA but it depends on frequency and TX pulse width.
                      • #41
                        ahaa
                        I think that reason for my around 100mA consumption is that my Hammerhead works on Passive Pull-down of Irf740. Can be better if I try to change it on Active Pull-down . Then I think that need to change pin1 with pin2 of IC11 ?
                        Then we will have 2A consuption? Detecting will be deeper ?
                        • #42
                          adding
                          And hotter IRF740
