Replies to Minipulse Plus
  • Coolmakina
    Hi again
    Bellow is what i am getting at? TP3 with my scope.
    If is something wrong, please warn me. Thank you.
    https://photos.app.goo.gl/rU8s9dXZtPR1TAn27
  • Qiaozhi
    Per Fig 14 of the assembly document, it should be like this:
    You can attach the damping circuit in parallel with the coil.
    I've added this useful diagram to the attachments here -> MPP Beach REV-E
  • Coolmakina
    Oh... Mr. Carl you made my day.
    Now i see a flyback.
    God bless you sir.
    Here is my flyback.
ID:	362471Click image for larger version
  • Carl-NC
  • Coolmakina
    Originally posted by Coolmakina View Post
    Hi Mr. Qiaozi,
    English is not my Mother language so its Also possible that i misread something.
    I built a monocoil.
    If we consider A to be the starting of the wendings, and B the finish tip. I joined both. Then splied to Wires de from the joint point, One to RX, another to TX.
    Is this wrong?
    "Have you shorted the coil?"
    I understand this as have jointed start of coil with end of the coil?
    If so, yes i did.
    Sorry if i am look like a dumb, which i acept to be a learning One...��
    This is my connection.
    From left to right. We can see 2 Wires..
    The One marked with green tape is the ending tip of the coil. I joined with the start tip. From there i soldered 2 Wires, One to RX another to TX. Then added the camping jig.
    Hope this PIC would clear what i Have done.
    When help to find what os wrong.
    PS: beside English not being my Mother language my phoen picks some caps and words for me...sorry Also about that.Click image for larger version
  • Coolmakina
    That sounds completely wrong. Have you shorted out the coil?
    Hi Mr. Qiaozi,
    I built a monocoil.
    Is this wrong?
    If so, yes i did.
  • Qiaozhi
    Both ends of coil (start and finish) are joined. Then from the joint One Wire go to pin 2 of TX connection, another go to pin 2 of RX connector. I Will upload photo of coil ASAP.
    Thank you very much Mr. Carl for the Help.
    Regards.
  • Coolmakina
    Looks to me like the TX is working but the coil isn't connected. Looking at your photo I'm not sure you have things connected correctly.
    Regards.
  • Carl-NC
  • Coolmakina
    IRFS840B should be fine.
    Unless they are bad.
    Seen a v?deo teste where testing with mult?meter set to diodo i shouldnt see voltage going trougth g and a of the MOSFET. Mines are ****fting voltage both ways. I think i Will replace them..
    Any others ideas?
  • Coolmakina
ID:	362458Click image for larger version
ID:	362459Click image for larger version
ID:	362460Click image for larger version
  • Carl-NC
  • Coolmakina
    Hi everyone,
    i'm still stuck on this step 4 of the minipluse plus.
    i started 5 units pcb, i wantend to build 5 minipluse plus. Along the way, 1 unit 79L05 was soldered backwards and still aside, It can be fixed later.
    i was able to do step 1, 2 and 3 on the others 4 pcb's.
    however i'm frozen at step 4.
    i bought a hantek 6022be digital oscilloscope to help me out. it's not a great machine but i could afford.
    the think is i don't have a large money fund to buy a decent one and a signal generator to proper calc the coil inductance and determine the damping resistor R4.
    so i dig Surfdetector videos, (thanks's surfdetector!), and i built a damping jig as he described.
    i also built a basket weave coil, according other threat's in this forum.
    but i not reading the 350V flyback on my scope.
    my probe and scope software is set to 10X, but peak to peak i only see 10,7V. and kind of a square wave trought the damping jig.
    i toke some photos but i computer is crashing when i try to upload them.
    is there any "check" i can make to see what is wrong with my step 4?
    all parts checked and they are as spec, except that i have installed IRFS840B instead of IRF840....could this be the cause?
  • Coolmakina
    Hi everyone,
  • Coolmakina
    You can make a simple square wave oscillator from a 555 timer circuit or a single opamp. Lots of info on the Internet for this.
    I was able to draw this scheme.
    I Will try to out this in to a proto-board or so.
