MPP coil test
    It would be good to figure out a way to do the testing without cutting and soldering to avoid the final joint(s) down near the coil.
      Well done in finding the original post Roo2,
      The soldering I was doing in the original writeup was actually done with my recommended twisted pair feed line which we know is a continuation of the coil wire itself. In the less desirable case of a different feed such as coax, the solder joints would be near the coil. With the twisted pair feed the solder joints are always near the printed circuit board.
      Dan
