Originally posted by convola
MPP beach rev-e problem
thank you. I used this cable to connect the coil to the circuit. When I removed this cable it became approximately 14us.Originally posted by Qiaozhi View Post
Your receive signal is taking about 100us before it gets above zero, so the problem is nothing to do with the sampling.
Is your coil severely overdamped?
you are right. it is aproximately 90us. How many microseconds does it need to be?Originally posted by Qiaozhi View Post
tp9 min and max position like this. reject pot min and max position.2 Photos
tp3 and tp2 like this. it is 100us pulse and 1ms period.Originally posted by Altra View PostLooking at your photo. It appears your Tx pulse is approx 400us based on your scope setting of 250us/div, This is not correct, it should be around 100us or less, Check all the capacitors and resistors around the NE555 timer U1. Maybe you used a 470n when it should be a 47n? I think if you fix the tx pulse your other problem with the first sample will be solved
In order to help others, how did you solve the problem?Originally posted by anil.berk View Post
Thanks for your reply Qiaozhi. I just solved the problem
Hi, I am also struggling with the same issue. I could not solve the problem on step 7.
