TGSL prints
  • TGSL prints
    Don't know exactly where to put those, so many topics on that subject.
    A member from forum asked me about dimensions of pcb.
    Last and best working TGSL configuration for me is this one, i made over the 30 units according to it.
    Some people don't have Sprint Layout, so here it is in PDF format too:
    Ivconic sir, thanks for the sharing, but i cant find post about your cableing, pot,sw,etc here, and some part is different with sticky thread by Qiaozi, sorry for the trouble.
      If you follow the schematic carefully; you can recognize all the components and cabling points.
      Those fets are J107 or BF245 (with reversed pinouts).
          Schematic :
            PCB photo view :
              I see, let me try.... will report here after got a clue....
                I think this is all ....
                Switch+pot
                  May I have your parts list and lettering?, its different from sticky thread part list
                    I guess there are minor differences, that's because TGSL "survived" dozen adaptations so far, maybe more...
                    At the time i projected that pcb and schematic (2004. or 2005. not sure...) i had very bad habit NOT to write BOM lists! Sorry!
                    I usually use schematic later and from if extract the BOM list if needed.
                    Shortly; i don't have it...
                      Here it is on the fly, unsorted, directly from the schematic:
                        Thanks sir, I will put all the remaining parts and buy the missing part, just to make sure about 22ohm resistor and one voltage diode 4v3 is not a wrong value of IN4148? Thanks before
                        This
                          This
                          [ATTACH]36733[/ATTACH]
                          Those are correct.
                            Dear Ivconic, can u please give quick comparation between 1265 version and cz 5?
                            I have one empty pcb, version cz5, but i dont have any file about placement components.
                            Which one working better?
                              At the time i had spare enclosures from Fisher CZ5 and Fisher 1265 metal detectors.
                              So i tried to draw TGSL pcbs to fit into those enclosures, therefore i named my draws like that; "CZ5 and 1265".
                              At the time i also was not very skilled with Sprint Layout (not saying that i am now), so my pcbs are not state of the art.
                              Both are made and working.
                              If there are some differences; than those are "chronological" differences, as i experimented much with various modifications.
                              Each one of those should work.
                              I don't remember the details, but luckily i used to wrote about those in TGSL topic. I guess everything is there.
