TGSL-Mini 100x70mm
  • #76
    Check shorts. Inspect your LM358 on working unit with scope and compare each pin with not working.
    • #77
      I think the input is wrong and causes the steady 7 Volt Output.
      Im not completey sure about the function of my EDU board. It was the cause for making a new version. I had only 16-20 cm with a weak tone.
      I will check it again later. This is so frustrating. I think i bought one lying LC-Meter and built a wrong coil with it , then i bought a DSO because of this. Then my DSO got damaged, i tried to make a new version of the pcb. Now i have two faulty units one broken DSO a wrong made coil and 20 PCBs of a maybe wrong Layout.
      • #78
        How is your DSO damaged?
        Its a pitty, it has relatively precious time, therefore you can precisely measure inductance...
        • #79
          I built it and it didndnt work, then i saw that a few pins are not properly soldered and i fixed this. It worked.
          Then after a while i couldnt adjust the line at the right side of the screen. I can move the wave up and down with it i guess.
          It works but i can not adjust this line.
          • #80
            Can somebody tell me what this additonal diode circuit in the oscillator does?
            • #81
              this a part of a feedback for stabilization of amplitude of TX sinus.
              • #82
                Thanks. Sounds good.
                • #83
                  Is somebody interested in helping me? I will send him a board from my TGSL 100 x 70mm for free if he will build it.
                  I got steady sound after i populated the board. I dont know what the problem is. It is possible that it is okay and i soldered something wrong.
                  I have to say that some holes are very close together (Transistors). I have black ones and green ones. The black ones have a bigger lead spacing for the 220uF caps.
                  Please only Europe.
                  • #84
                    Okay, Hyena will help me. Thanks, PM sent.
                    • #85
                      Neither the Russians will fool me. I knew I have seen this Tx oscillator before, finaly I found it
                      Its Gold mountain king cobra!
                      • #86
                        Please only Europe.
                        Put pictures of your board( unpopulated) and I will trace it with schematic to make sure it is good layout.
                        • #87
                          You can use the Sprint Layout file from this thread. It should be the same.
                          I can not make pics from the black board because it is black.
                          I have a green one too but the populated one is a black one.
                          I sent one board to bernte one and one to hyena. I think bernte will wait until i have solved my problem and hyena will help me in about two weeks.
                          EDIT: In Post #24 is a picture of the green one front and backside. It should be the same.
                          • #88
                            Ok , its been a while now. I sent one Board to Hyena a few Months ago and he built one and got it working.
                            So i think the Layout is ok.
                            • #89
                              bunu nereden aldınız
                              • #90
                                GMT king cobra is sure copy of tesoro royal sabre.
