TGSL - EDU , new boards and kits
  • bernte_one
    hello,
    i will try to make a working dd coil this weekend.
    Hope it works.
    I will use 0,28mm enamled copper wire TX 100 turns RX 105 turns.
    Happy winding 1,2,3,4,5..........
    on which hole on the bord i connect the RX start/end and the TX start/end
    i know at the point where tx and rx is printed on but is it important to connect start / end in a special point
    or only that rx and tx are right placed no matter were it starts or end?
    greetings b.m.
  • lunamay
    i'm trying to finish tgsl but i stopped the work because i'm waiting for plastic sheets for coil enclosier..now working on original tesoro silver sabre umax board
    best regards
  • bernte_one
    anyone else who´s on work with tgsl?
    pics?
  • bernte_one
    if you had a 4 month child and a woman and you stay the nights with soldering boards instead of sleeping they will become sexy believe me
    they are quiet, they a golden, and if you make allright it makes horny sounds
    p.s.
    all just fun (i would only say it´s good done work by eduardo the forum ApBerg and silverdog and his supplier...)
  • bklein
    My Brazilian girlfriend is sexy. A pcb will never come close to being sexy.
  • bernte_one
    Hello,
    i think there is no problem with the resistors. whether you solder them flat on board, in ancle of 45 degree or vertical. it is just a question of space. In the end the values of the resistors are the same. The boards are sexy!
  • bklein
    There is a difference between different brands of resistors. All are 1/4W but some must have some form of metal hardening on the leads at the resistor body that makes them less pliable and they don't bend a sharp 90 degree bend close enough to the body to fit your hole spacing. I too just went to my parts bin - first part I tried was fine, next one was not. Body dimension visibly the same. I'm just sayin.....
  • silverdog
    I don't design the boards, just get them manufactured and offer them to the forum
    The spacing is actually correct and I have just placed a few flat onto the board, no problem
    I guess the photo is a result of the resistors moving when soldering, at the end of the day they work as well as flat ones
  • bklein
    Hi Silverdog,
    How about making your standard resistor lead spacing another tenth inch longer?
    (check photo this thread)
    I think you need to commit to whether the resistors stand up on end or lay flat.
    As it is now, they just look....~wrong :-) If new builders are thinking they should lay flat they may be damaging their resistors trying to make them so.
    Barry
  • SVEN1
    Is this GS version a multi tone detector or single tone?
  • Qiaozhi
    The coil diameters shown in the image are the same as the standard Tesoro (brown) polo coil.
  • bernte_one
    hello
    i´ve found this
    and this
  • bernte_one
    yes thanks, i have seen it already but maybe there some other possibilities like in the md4u.ru forum for the silver sabre it is a concentric coil not a double d but i have seen some people they build the concentric and say it doesn´t work but it was here in german forum some years ago
  • dfbowers
    hello,
    who has a working selfmade coil and can post his coil datas
    size,wire material, coil connector plug, type (concentric, double D or other?) etc.
    thanks
    Bernte_one,
    It is all here:
  • bernte_one
    working diy coil
    hello,
    thanks
