coil TGSL help me pleace
  • coil TGSL help me pleace
    Hi all I'm putting together the TGSL that I began to arm QIAOZHI posting coils and finish as the post says the coil RX and TX 107 laps 98 laps right now as I do not have a measuring inductometro gives me strength and nearly equal RX = 9.7 TX = 9.8 ohm ohm this is good or has to be greater resistance diferncias between coils
    You need to achieve 6mH for tx and 6.5mH for rx. It's the inductance and not the resistance...
    Your resistance is too low and in my mind, your wire
    is too big!
    It's not 0,25mm?
    Good luck for your project!!
      inductance
      if I understand the difference between inductance and resistance, the question is.
      with a coil resistance well calculated that would have to be when measured with a tester
      so I could more or less know or come close to this ideal inductance
      PS: the wire is 0.25mm might not be appreciated by the photo too close
        If you have followed the instructions provided by Ivconic, even without an inductance meter, you should not have a problem. You're main difficulty will be balancing the coils correctly, but Ivconic has even provided a simple method for doing that.
          calibration coils
          Thanks for replying do you know the link of this post I have enabled status seeking but can not find greetings
            Everything you need is here -> http://www.geotech1.com/forums/showthread.php?t=15710
              Tank you Qiaozhi
                Hello,
                forum member selim made a video of his working tgsl
                he wrote that he uses for his rx coil 14mH
                and only one of his coils is shielded i dont know rx or tx
                but it seems to work
                can anyone confirm that
                the other fact is that some users take metal cases for tgsl other plastic cases
                can i increase performance when using metall case
                which cables should i connect to metall case
