SpiMX PINNACLE
  • SpiMX PINNACLE
    Improved design.
    1. Quieter Analog supply (lower noise).
    2. Separate supply for coil (allows using separate higher voltage supply to coil)
    3. Simpler Bi-Polar pulsing circuit.
    4. Uses Arduino Due. Mega-powerful 85MHz 'Arduino'. Allows easier understanding and customization of the firmware.
    Hi Tec,
    Thanks for the pdf.
    Bipolar pulse, interesting ! Do you have any scope shots showing tx in action ?
      Scope shots
      Attached is scope traces:
      1. Pulses train across the coil
      2. Close up of single pulse at coil.
      3. Pulse at Test Point 5, before the amplifier.
        I have made a website for this detector.
        Tec
          Congratulation on this project Tec.
          Especially on 3D printing parts. Are those 3D printing parts enough robust for everyday loads?
            Thanks,
            They are ok so far, after about a dozen uses over a few months.
            The coil and coil-mount are filled with epoxy.
            The other parts are PLA plastic straight off the printer,
            I plan to take them underwater soon.
            Tec
              Arduino code published
              Schematic updated
                Hello TEC.
                Great work...I`m impressed
                Would love to give this on a go..
                Are PCB`s available?. If so please let me know price/postage to Australia
                My Emal: [email protected]
                Thanks in anticipation
                  What kind of switch is U14? Its not marked.
                  I would like to give this project a try.
                  Thank you
                    Hi, U14 is a 4011 (Cmos NAND gate). Sorry for missing the part number on that.
                      Cool. Thank you. The video is not working. Anywhere to see how this device works?
                      Thank you
                        Hi Tec,
                        Is pcb layout available?
                        I started laying it out in eagle but afraid to screw something up.
                        Thank you
