NEW TECH PHOTOS
  • #31
    Originally posted by nick_f View Post
    Hi Tony,
    It looks like you completed the series of photos for your targets. I will process them tonight and attach them here.
    Nicolae
    Hi Nicolae,
    If I can get a team together to make an "Open Source" design, Discriminating IB-PI, I am going to ask Carl to give us a dedicated forum for it.
    I would like to invite you to participate in the team.
    Tinkerer
    • #32
      You need to think of a clever name!
      • #33
        I am thinking of a basic model, that will be easy to build. This way many can build it and try it in the field, so hopefully we get a lot of feedback for a full blown model with more Christmas tree lights and bells and whistles.
        Everybody is invited to share their knowledge in the project and the team.
        The first job of the team will be to chose a name.
        The second job will be to select some loose, basic parameters.
        I am thinking of loose parameters, because, this being a worldwide effort, it is often very difficult to find the exact parts to replicate the design.
        So I am thinking more of a worst case approximation, that will be easy to reproduce.
        The advantage will be that we end up with a variety of executions that we can compare and thus learn from it.
        Tinkerer
        • #34
          Hi Tinkerer,
          I think that it should be named "The Tinkerer PI" As all of the tinkerers around the globe will be doing just that!
          Cheers
          • #35
            Originally posted by Mechanic View Post
            Hi Tinkerer,
            Cheers
            Hi Mechanic,
            not a bad idea at all, it fits in with the "loose parameters".
            Anybody second that name?
            Tinkerer
            • #36
              I like short names.
              What about Ti-PI
              • #37
                I concur.
                • #38
                  Hi All,
                  Here are Tinkerer's photos, with the signal for no target superimposed on every image. At this stage I realised I should have added some text about the ownwer of the photos (Tinkerer). He also asked me to take credit for editing the photos, which I do hereby
                  Nicolae
                  • #40
                    Hi Nicolae,
                    congratulations for a fabulous job. Now one can really see the various responses for various targets. I even feel like buying one of these detectors myself.
                    Tinkerer
                    • #41
                      Originally posted by hobbes_lives View Post
                      I concur.
                      Thanks hobbes,
                      Let's call it TINKERERS IB-PI.
                      Next job, parameters. What are our goals?
                      Tinkerer
                      • #42
                        Tinkerer, I was looking at the graphs and I am puzzled why there is such a big difference between the cannon ball and the steel lugs and steel nails. Isn't the cannon ball made of iron too? I would suggest to take another photo just with a very rusty nail (because we have much more (mis)chance to find rusty iron than steel lugs). And if it happens that you have some hot rocks in your collection, maybe you should take a shot of those ones too. By the way, I discovered that my hot rock attracts magnets, in fact I can hold the rock suspended by a neodymium magnet.
                        Nicolae
                        • #43
                          You've set the first goal in your statement above...
                          I am thinking of a basic model, that will be easy to build. This way many can build it and try it in the field...
                          • #44
                            OK, but, lets go a bit further.
                            Purpose: Relic hunting? Coil hunting? Gold nuggets?
                            Power: 500mW, 1W, 2W, ? This concerns mostly TX power, for the rest of the circuit we look where we can save power but keep it simple.
                            Coil diameter: Medium = 10 to 12", small = 8 to 10" ?
                            I would like to get some feedback by team members.
                            Again, everybody is invited to join the team. I did make a few direct invitations, but then I realized that this might look as if I am just trying to generate a lot of posts.
                            So please Max, Qiaozhi, B^C, Porkluvr, EVERYBODY is invited.
                            Tinkerer
                            • #45
                              My quick reply wasn't ample, huh?
                              My suggestion would be to initially design a light-weight unit for coin/relic hunting utilizing an 8" coil. (Hays has a couple of 8" housings that would work well.)
                              The TX power should be determined as the design progresses, due to all of the trade-offs between TX power, battery consumption, battery size, unit weight, etc., which are all dependent on the pulse width, pulse frequency, coil parameters and driver circuitry.
                              A primary goal should be to achieve some form of ferrous/non-ferrous discrimination. Your IB-PI experiments should obviously be the stepping stone for this goal.
