now the spice circuit simulation files of the last PC sound-card interface modules will be available. I have lowered the DC/DC converter clock frequency to make the simulation faster. The positive supply voltage will therefore be fed from a fixed 10V supply. The simulation takes quite long time.
To make a full spice simulation of all parts, change the DC/DC converter clock frequency to the desired operating frequency and feed the UC+ into the +5V regulator.
Set LTSpice into the "Alternate" engine. Whole parts of the presented modules are now the PCPI sound card interface module.
. Which represents the different time constant of the target
. This makes save discrimination of the PI technique possible. Quite surprizing result on the slow decaying coil with less target eddy current stimulation. I will build a two channel pre-amplifier to make more experiments on this. And it is quite non-critical with DD coils now. I very likely won't have the much ground effects like in the VLF's. I just need to amplifiy the low receive signal on the DD receive coil to see more signal response.
