Advanced PI coils
  • Ferric Toes
    Wire frame pic:
    [ATTACH]22691[/ATTACH]
    Spiral pcb coil 1970's style. How the artwork person did this at the time is a mystery. No computer programs then; it was all down to adhesive black tape. This is probably the first PI pcb coil attempted anywhere.
    Eric.
  • Aziz
    1 Million Dollar Question Quiz
    Hi all,
    you know, I like quiz games.
    Here is a 1 Million $ question quiz for you.
    What is better regards to mono PI coil performance and SNR:
    1. a more compact coil bundle with less copper and less turns count or
    2. a wide & thick coil bundle with more copper and more turns count?
    Both coils (1. + 2.) have the same inductivity.
    2. coil has more resistance and obviously less interwire capacitance. But filled with a lot of "air". Coil looking like a donut coil.
    This is a consequent question towards the UCT due to the last finding. What do you think?
    PS: Damn it, but I don't have 1 Million $ to pay the winner.
  • Ferric Toes
    Hi Bob,
    But you have a much more current drive.
    Current is inductance limited for full coil, so for 1/4 inductance it will be resistance limited (depending on pulse width and total coil circuit resistance). However, if the current doubles in half of the inductance you are back to square one i.e. same as a normal mono.
    Because the centre tap at 1/2L is not going to be a 1/2Turns, will this not give an unbalance to the common mode response. I expect a balance point for the CT could be calculated.
    Ground noise is a big issue on Oz ground. And this gets more critical with half coil driving.
    No reason for this that I can see.
    Eric.
  • Aziz
    Wasn't Tesla the one that lodged the patent on a spiral coil?
    Yes, Nikola Tesla was a great person & inventor. He is one of my favourite scientists.
    I think its going to be very difficult to convince a patent examiner to give his Ok for a new spiral coil patent.
    *LOL*
    (Oh yes, I forgot: it's only a question of "Fakelaki"/"Bakshish" (money) today.)
  • Aziz
    Originally posted by techo_bob View Post
    Hey Aziz
    How about a centre tapped spiral coil into a full differential amp
    would that help !!!
    Bob..
    Hi Bob,
    it is really nice, that spiral coils can be made center-tapped using the bifilar coil wire. The only advantage is, that you can drive it at L/4 (=coil half) to push more current and damp and receive at both coil halves. There is no benefit regards to EMI noise induction. When you sample at both coil halves, you have the twice target response and the twice EMI noise induction as well. But you have a much more current drive.
    Cheers,
  • Aziz
    Hi all,
    BTW, I have to mention, that the spiral coil response calculations were done at the z-axis and the calculated figures in the first few inches does not contain the maximum target response. Only at the center axis. This is the reason, why you get strange relation figure at 2 inch detection depth. The mono coil response does contain the maximum response on its edge and the spiral coil doesn't yet (would require very time consuming coil calculations). Just ignore the strange relation in the first two response depth.
    Some notes on the spiral coil:
    It is obvious, that it isn't optimal for highly mineralized ground due to stronger magnetic field strengh on the center region. You will get more ground noise of course (don't confuse with EMI noise). A good compromise would be a round TX (as usual or semi spiral) and a separate spiral RX, which is smaller than TX. So not all magnetic flux of the TX is linked to the RX spiral coil. The RX spiral beginning could even be smaller than 0.5 diameter units of the TX coil.
    Let's continue with the WBCT ... to find the ultimate coil technology (UCT).
    Anyone want to oppose now?
    Cheers,
  • techo_bob
    Hey Aziz
    would that help !!!
    Bob..
  • Davor
  • dfbowers
    Nice work Aziz. I enjoy reading your daily posts very much.
    Back in the day of BFO detectors, I built a small spiral coil that outperformed just about anything else I could come up with. They work great on Telsa coils too!
    Don.
  • Aziz
    The Spiral PI Coil Pics
    Wire frame pic:
    Magnetic field strength pics:
    Cheers,
  • Aziz
    Surprise! Surprise!
    Ok guys,
    another magic is happening here. Fortunately, this spiral coil is prior art and nobody can lock it with evil patents anymore. Pity, but I didn't invent it. And it works pretty well and is even outperforming the mono coil. As I said before, never give it up! How is that now?
    Spiral coil:
    Beginning from 0.5 unit diameter (=5 inch) and ending at 1.0 unit diameter (=10 inch). 35 loop turns (but I'm using internally in my coil software N=34.7).
    Unfortunately, this flat spiral PI coil is picking up approx. 9.7% more EMI noise. So the total coil flux area is 9.7% more compared to the mono coil. On the other hand, it is performing exceptionally well. In the relation comparison below, the 9.7% more noise is divided out (by multiplying the relation by 0.912). So we see the SNR corrected relation and is a good comparison to the mono coil regards to SNR criteria.
    Coil Comparison (Calculated Response Ratio to Reference Coil)
    © 2012 by Aziz Ögüt. All Rights Reserved. 10-Jan-2013
    Reference Coil: 300 µH Round Mono Loop Coil
    10" Spiral PI Coil (0.5 DU .. 1.0 DU)
    Target Depth [inch] Target Depth [cm] Relation to Reference SNR compensated (9.7 % more EMI noise)
    1 2,5 3,007
    2 5,1 3,949
    3 7,6 3,085
    4 10,2 2,433
    5 12,7 2,034
    6 15,2 1,783
    7 17,8 1,618
    8 20,3 1,504
    9 22,9 1,424
    10 25,4 1,365
    11 27,9 1,320
    12 30,5 1,286
    13 33,0 1,259
    14 35,6 1,237
    15 38,1 1,219
    16 40,6 1,205
    17 43,2 1,193
    18 45,7 1,183
    19 48,3 1,174
    20 50,8 1,167
    21 53,3 1,161
    22 55,9 1,155
    23 58,4 1,150
    24 61,0 1,146
    25 63,5 1,142
    26 66,0 1,139
    27 68,6 1,136
    28 71,1 1,133
    29 73,7 1,131
    30 76,2 1,129
    Now look at this magic stuff. I'm really impressed. There is a coil now, which is outperforming the mono coil with ease. One have to tame the shielding capacitance somehow.
    Cheers,
  • Orbit
    excellent Demonn!!!
  • Aziz
    Practically, this type of coil performed better than standard, dual field or any other configuration so far, tested with standard detectors, or some weired configurations custom built to utilize it.
    You're dead right according to my first coil simulation! But I have to check the SNR yet.
    (Hey, the result was an incredible surprise to me, that I've began to check my coil software and coil model .. But there isn't any mistake.)
  • deemon
    Deemon, how should be controlled the balance circuit - automatic or manually?
    How the balance circuit with MONOCOIL will suppress the GND signal?
    If we use the coil in a classic VLF detector ( with X-R discrimination ) - we can use manual balance , why not ? It can be stable enough , especially when we need to balance only one parameter ( inductance ) - for example , like I did in my "Faraday bridge" circuit , described here - http://www.geotech1.com/forums/showt...3-mono-coil-IB . Or if we don't want to tune it manually - it can be done electronically , during the turn-on procedure , it's not a difficult task .
    But here is even more interesting idea - full automatic balance during operation time . Of course , it needs more complicated electronics , but I found very interesting solution , and now finishing the circuit based on it . Of course , there are some problems ... but I hope to solve them all successfully .
    P.S. And what about GND signal suppression - I believe that this task must be solved only by electronics , utilizing the different behaviour of magnetization ( and demagnetization ) of magnetic minerals and metal targets . Why I think so - because all methods of ground balance using coil construction depends on such parameters as a distance between the coil and the ground , or maybe tilt of the coil ( with some 8-type coils ) , ground gradient , and other disturbing factors .... so I don't suppose these methods to be reliable enough . And it's also true when we speaking about RF interference cancellation ...
  • Tepco
    This flat spiral stuff is interesting. I tried many different flat spiral configurations before, similar to what you going to simulate, very interesting coil configuration ( i even posted some design here time ago). I never made any computer sim. on it but just based on experience, something similar to your model, roughly 300uH, 30 turns, 2/1 OD/ID ratio works perfectly good, made of two wire speaker cable. Main reason for this physical configuration is increased inter winding distance between turns, filled with insulation, reduced total self capacitance and faster sampling. However, more interesting ways to use similar coils are obvious.
    Similar to bifilar center tapped , 2wire flat spiral is also combination of two, physically and electrically identical, tightly coupled coils, but electrically insulated. Very interesting designs can be developed (i tried ) using this configuration. Say, center tapped bipolar pulsing (some issues here with shielded coil), or multi period pulsing, using constant current drive and two different voltage power supplies, or floating TX from RX part, or differential for noise reduction, or... whatever.
    Practically, this type of coil performed better than standard, dual field or any other configuration so far, tested with standard detectors, or some weired configurations custom built to utilize it. Biffilar coil can be similar, enabling lot of testing and experimentation to be done. Interesting.
