HI Carl,
If not enough current is put into the coil, the 180v cap will not reach the 180v and this will in turn prevent the front end fet cct from operating. It might work, it might not work.
Bill,
That part is a diode, it used to be a byv 28-200, it is most likely now an murs320.
If you are able to hook the scope ground up to pin 5 of the coil plug, this is detector ground. The yellow wire is the receive ground(linked in the coil plug on the coil side)
The blue is the receive wire, pin 4 is the transmit wire.
You can use a normal coil for the testing at this stage, just don't bother listening to the audio. Even later on we can use the normal coil to test that the target response is making it through to the final stage before the micro by using the scope.
Cheers Mick
Bill,
Cheers Mick
