One other thing I have found is that winding a neat tidy layered coil does NOT help depth (or seem to). Some of the best coils I have made were ones I scramble wound to test a front end. Bizarre or what?
DIY Mad Litz Wire for ULTRA FAST PI Coils
Neatly layering the windings will result in maximum inter-winding capacitance (i.e. a slower coil).Originally posted by Sean_Goddard View PostOne other thing I have found is that winding a neat tidy layered coil does NOT help depth (or seem to). Some of the best coils I have made were ones I scramble wound to test a front end. Bizarre or what?
Hi all I haven't posted here before but have been following for a while Id like to mention while making my own litz wire I also found it tended to twist into a heap .so on one of my experimental coils for a minelab I whipped a very thin spread of engine gasket silicon then applied the twist and let it dry .what I found is the wire was easier to use like a lenth of rubber .the coil seams to work ok .I don't no however because I don't have a scope if there is any negative effects .
Originally posted by Jose View PostHi Sean Goddard
Thank you for sharing this interesting topic.
Unfortunately some concepts I can not understand, partly by the translation and by my ignorance of the subject.
Would appreciate if someone does a graphic scheme, or publish an image to understand better.
Thanks again, best regards
Jose
Basically litz wire is use in making coils in radio applications. In practice current does not flow evenly thru the cross section of a wire but tends to use the surface of the wire....Known as skin effect. By bundling thinner wires the surface area is considerably higher for the same wire diameter. This translates to lower resistance to higher frequencies. Suggestion is to use proper litz wire for better predictable performance. BTW commercial litz wire uses very fine strands and is bound with a cloth type material sheath whilst still maintaining high flexibility
When operating pulse induction metal detectors at low delays, below 10 micro seconds, any lingering eddy currents in the coil wire itself could be detected. Typically, thinner strand wire below about AWG30, will not hold many eddy currents. Using thin tinned strands puts a slight resistance between the strands and minimizes eddy currents in the tinned stranded wire bundle. Silver coated stranded wire does not offer these benefits as silver is a good conductor. Litz wire is good but you need to make sure that each strand of Litz wire is making a good coil connection to have the maximum current flowing.Originally posted by phred01 View PostBasically litz wire is use in making coils in radio applications. In practice current does not flow evenly thru the cross section of a wire but tends to use the surface of the wire....Known as skin effect. By bundling thinner wires the surface area is considerably higher for the same wire diameter. This translates to lower resistance to higher frequencies. Suggestion is to use proper litz wire for better predictable performance. BTW commercial litz wire uses very fine strands and is bound with a cloth type material sheath whilst still maintaining high flexibility
Joseph J. Rogowski
below 10uS i have frustrated Coax DetectedOriginally posted by bbsailor View PostWhen operating pulse induction metal detectors at low delays, below 10 micro seconds, any lingering eddy currents in the coil wire itself could be detected. Typically, thinner strand wire below about AWG30, will not hold many eddy currents. Using thin tinned strands puts a slight resistance between the strands and minimizes eddy currents in the tinned stranded wire bundle. Silver coated stranded wire does not offer these benefits as silver is a good conductor. Litz wire is good but you need to make sure that each strand of Litz wire is making a good coil connection to have the maximum current flowing.
Joseph J. Rogowski
As delays drop to 10 uS and below coil construction and attachment to the coax cable requires some creative designs to prevent the coax cable and solder joint to the coil from being detected. Some forum members extend the coil wire as a twisted pair up to the control box to eliminate this joint. If you can use this twisted pair design all depends on the noise in the area where you are detecting.Originally posted by Wahyu View Postbelow 10uS i have frustrated Coax Detected
Here are the things that collectively allow early sampling.
1 Fast preamp response after coming out of saturation. Using a dual stage, low gain and higher preamp voltage power source will tend to speed this up.
2. Minimize all capacitance in the TX circuit including coil turn to turn capacitance; coil to shield capacitance; coax capacitance, coil driver MOSFET COSS.
3. A higher damping resistor value indicates less capacitance to damp and thus a faster coil.
4. Power of the TX pulse. Higher power TX pulses need lower damping resistor values.
5. The soil where you are detecting. Wet salt sand will respond at about 15 uS delay.
There is no single right answer. It all depends of what targets you are seeking, the electrical noise environment, the soil environment and size of the coil relative to the target size.
Read various coil forum posts to see how other forum members have attempted to speed up their coils.
Joseph J. Rogowski
- Likes 1
Why should Tx power(4 above) have an effect on the damping resistor. I was thinking the resistor damped a LC resonance and power would have little effect.Originally posted by bbsailor View PostAs delays drop to 10 uS and below coil construction and attachment to the coax cable requires some creative designs to prevent the coax cable and solder joint to the coil from being detected. Some forum members extend the coil wire as a twisted pair up to the control box to eliminate this joint. If you can use this twisted pair design all depends on the noise in the area where you are detecting.
Joseph J. Rogowski
This is just an observation based on seeing the lower peak fly back voltage when the coil DCR and series resistor DCR cause a lower fly back voltage below 100V and short TX pulse widths between 30 to 60 uS at about 3000 to 10000 PPS allows for higher value damping resistors. The CS6PI is a low power example of this that has the potential to be made faster than its initial design.Originally posted by green View PostWhy should Tx power(4 above) have an effect on the damping resistor. I was thinking the resistor damped a LC resonance and power would have little effect.
L/C is a easily measurable variable to speed up a coil but power to be damped also plays a role maybe to a lesser degree. You can easily test this by putting a resistor in series with the coil to reduce the fly back voltage and see how changing just this variable affects the damping resistor value.
Joseph J. Rogowski
Using a coaxial cable doesn't become a silver bullet in all cases. To get the benefit of coaxial shielding etc a basic requirement must be implimented to take advantage of shielding & signal delivery. In radio work the driving & receiving circuits must present the impedance that of the coaxial cable used otherwise there will ring/standing waves that will interfere with signals < 10us. Assuming u have PI that delivers a current into the coil so some of the energy ends up on the coaxial cable flowing up & down the length coaxial cable (ringing) only after it dies down that u will c the return signal from the target. So the solution is put ur amp @ the coil's o/p & c if there is an improvement. If this helps then do impedance matching @ both ends of the cableOriginally posted by Wahyu View Postbelow 10uS i have frustrated Coax Detected
Thanks for the interesting topic guys and Joseph in particular;-). I start thinking of SWR meter at the coax(kiddingOriginally posted by bbsailor View PostTo everyone tinkering with coils,
Here is a link that will give you more information about Litz wire. http://litzwire.com/nepdfs/Litz_Design_PDFs.pdf
The most important thing to consider is the actual strand size as the strand sizes are frequency dependent. An AWG 30 strand would be good to use from 1KHz to 10KHz. As the frequency goes up the strand size gets smaller.
I hope this helps.
Joseph J. Rogowski
. My question is what is the typical frequency Surf PI 1.2 is working on,so i can choose the proper litz wire for the coil. The amount of information i get here and in the net is only confusing me.The bunch of standards(AWG,SWG etc) is only making the stuff harder. So i see somewhere surf pi operates on 15khz but for sure it can be adjusted in some border as well. Than where is the golden middle or typical frequency range it will work and is still the AWG30 maximum/minimum size of wire advice applicable for litz too? Thanks.
The pulse rate of the Surf-PI is nowhere near 15kHz. In fact, the Surf-PI uses the same oscillator to generate the audio frequency.Originally posted by nonkapo View PostThanks for the interesting topic guys and Joseph in particular;-). I start thinking of SWR meter at the coax(kidding
If you look at the 555 timer circuit, you will see that R1=100k, R2=3k3, and C1=22nF. These values give a pulse rate of 622pps.
