I have been building and experimenting with a PI detector based on the Hammer head. See my thread about this project here:
http://www.geotech1.com/forums/showt...ake-on-the-HH2
Now to keep things simple to start I have not shielded the coils or used shielded cables (see pictures in my thread).
Whereas, in all coil build threads everyone adds shielding to the coils either by wrapping the coil with shielding material or applying a shielding material to the coil housing. Lots of threads on different shielding methods.
The shield is supposed to cancel the capacitive effect of the ground (and possibly reducing noise) and a test is moving your hand near the coil or moving the coil closer to the ground. If no response then the shield is working. However, I have no response without any shielding.
The biggest down side of a shield is the added capacitance which increases the decay time of the coil and needing a smaller Damping resistor value. So if a shield is not really needed then the coil can be "faster".
I did have issues with wobbly audio but this was solved by a fine adjustment of the Pulse frequency. I did try shielding but did not change this wobbling.
So this is simply AC mains beating with the pulsing frequency.
Is there something I am missing?
I am close to finishing coil builds which will be epoxied into shells. It will be next to impossible to make changes after applying epoxy so what to ensure I am not making a big mistake.
Is there anyone that has build un-shielded coils for a PI detector and not have issues?
Or is everyone just shielding the coils because every thing they read says to shield the coil?
