Tesoro Tejon coil
  • Tesoro Tejon coil
    I am making a DD coil for a tesoro tejon. The TX section is measuring 17.4 Khz on a frequency counter. The RX coil is apparently non resonant on this detector. On a dual trace scope, the RX sine wave is leading the TX sine wave. Should'nt the TX sine wave lead the RX signal on this detector? How do I make the RX signal lag the TX signal? add more turns to RX coil? I am trying to get ground balance and discrimination to work properly.
    If the RX leads by just a few degrees then it is likely due to the the TX coil resistance and is normal. The GB & Disc phase comparators should account for this if you've gotten the TX coil specs right.
      Thanks for the reply Carl, no the Rx is leading by about 40-60 degrees.To get the Rx to lag, do I add turns to the Rx coil?
        Do you have the original coil?? If so measure the phases to use as a reference.
        Does the Tejon have a similar circuit to the Golden Sabre?
          No I dont have the original coil to compare. As far as I know the tejon and golden saber are completely different.
            I'm pretty new to this but do have 3 dd coils for the Tejon. 10x12 wide scan, 8x11 dd and a Cors Shrew as well as the stock 8x9 concentric.
            The 10x12 widescan is a much better coil than the 8x11.
            I do have a dual channel scope so if I can make a measurement for ya I will, just let me know where you are reading from on the machine.
              Thanks KAC, connect channel 1 (TX) on scope to TX coil pin. Connect channel 2 (RX) on scope to pin 7 of 33178 chip (its the ic chip on the top right corner of the board.) and please show a picture of the scope screen.
                I am trying to find something usefull on my disk, relating to this.
                Not sure if any of this will help:
                RX 16.56m 67.4 ohm
                TX 1.03m 045ohm
                Tejon-SEF 10/12
                25,4cm x 30,48cm
                Rx - 160 turns , 0,20mm.
                Tx - 40 turns , 0,38mm.
                  Thanks Ivconic, your always helpfull! I am building a 10 inch DD coil and I am trying to get the best phase on the scope for best discrimination.
                    A question to coil builders: The tejon TX coil is resonant at 17.5 khz, but the RX coil appears to be non-resonant, its capacitor is series connected. Ive seen widely different inductances on RX coils made for the tejon from different sources. What determines the non- resonant RX coil inductance (number of turns) to maintain proper phase relationship with the TX coil for good discrimination and ground balance?
                      If the RX coil has a series cap then it is resonated, but series resonance instead of the typical parallel resonance. You need to get the RX inductance reasonably close to maintain a proper RX phase so I'm not sure how widely different inductances will work.
                        What about the grounds? Clip them together and ground to the board?
                        Also do this with a coil on I assume.
                          Depends on the design, I don't know how the coils are connected on the Tejon.
                            Hope this help,
                            Nel Tornado spec
                            TX 910uh 3.2 ohm
                            RX 17.9mH 74.9 ohm
                              Per that schematic, the TX shield connects to filtered -5V and the RX shield connects to ground.
