Do you think 36c4p is diode ?
vanquish Tiny PCB
you do not see the micro on board. thats this chip with 6 pins like a smallest black bug. oh... you still do not know ML is evil, your happiness.
Thanks dear kt315
But copying the tiny PCB (inside coil) do not need to code (micro).
What we need, it is copying the pcb map and knowing its component.
After that, we can redraw it as Through-hole with equivalent component.
you need to get a code for the micro. ML is again on their wave. nobody must not have a chance to do a copy of coil.
vanquish Tiny PCB
Hello
Dear All
I created this thread to discuss and share our experience about tiny PCB of vanquish which is located inside of coil.
Yesterday, i opened my vanquish coil with difficulty and could reach to the PCB.
The PCB is strongly protected by ML because it has a different material for protecting.
Anyway, i almost could get the PCB but a resistor and three transistors is crashed during opening.
Unfortunately, i don't have the expertise to reverse engineer it. So, i share its pics (PCB, X-ray of coil and conceptual schematic of its pins) here. Maybe someone can help to do it.
X-Ray1
X-Ray2
PCB
I forgot to say, IC opamp of the PCB is T062 (i think it's TL062)
I also realized that Mr. Foma has been able to draw the schematic of EQUINOX. I think base of the Vanquish and EQUINOX pcb is the same. For better understanding, i also attached Mr. Foma's schematic.
Foma's schematic (EQUINOX Schematic)
Mr. dbanner also has been pointed to a possible mistake in Foma's schematic and edited it. I also attached his version.
I hope this information can help to reach a correct schematic for vanquish tiny PCBTags: None
