vanquish Tiny PCB
  • h9361
    Dear kt315
    Do you think 36c4p is diode ?
  • h9361
    Thanks.
    But i can not still understand.
    See the board, there is not any micro chip (6 pins).
    I think your means is 20T chip in Equinox schematic.
    I attached a higher quality photo.
  • kt315
    you do not see the micro on board. thats this chip with 6 pins like a smallest black bug. oh... you still do not know ML is evil, your happiness.
  • h9361
    Thanks dear kt315
    But copying the tiny PCB (inside coil) do not need to code (micro).
    What we need, it is copying the pcb map and knowing its component.
    After that, we can redraw it as Through-hole with equivalent component.
  • kt315
    you need to get a code for the micro. ML is again on their wave. nobody must not have a chance to do a copy of coil.
  • h9361
    started a topic vanquish Tiny PCB
    vanquish Tiny PCB
    Hello
    Dear All
    I created this thread to discuss and share our experience about tiny PCB of vanquish which is located inside of coil.
    Yesterday, i opened my vanquish coil with difficulty and could reach to the PCB.
    The PCB is strongly protected by ML because it has a different material for protecting.
    Anyway, i almost could get the PCB but a resistor and three transistors is crashed during opening.
    Unfortunately, i don't have the expertise to reverse engineer it. So, i share its pics (PCB, X-ray of coil and conceptual schematic of its pins) here. Maybe someone can help to do it.
    X-Ray1
    X-Ray2
    PCB
    I forgot to say, IC opamp of the PCB is T062 (i think it's TL062)
    I also realized that Mr. Foma has been able to draw the schematic of EQUINOX. I think base of the Vanquish and EQUINOX pcb is the same. For better understanding, i also attached Mr. Foma's schematic.
    Foma's schematic (EQUINOX Schematic)
    Mr. dbanner also has been pointed to a possible mistake in Foma's schematic and edited it. I also attached his version.
    I hope this information can help to reach a correct schematic for vanquish tiny PCB
