Low capacitance coils
    Thank you Mike!
    I will keep that in mind, as I build this later. I'm just in the planning stages now, while waiting for parts. I hadn't noticed that post - but I did look up the capacitance per unit length of various coax, and it is quit high ( about 25pf / foot ), and somewhat lower for high-Z coax (75 or 300 ohm hardline).
    As for low "capacitance coils", I ran into some posts that told about the dielectric constant (DC) of the coil form, and wire insulation, etc. That caused me to look into some low DC materials. And I remember old high-Q / low-capacitance coil winding tricks from long ago, and the coil forms like basket weave, etc. Anyway, here's what I found about the low DC materials.
    Air....... The best dielectric - which is 1.00.
    Plastics........
    Polypropylene: 1.25 - 1.8. [ Widely available in the US, at Walmart, etc ]
    LDPE: 2.3 [ have not found any yet ]
    NOTE: Polypropylene is identified in the US, by the triangle recycle symbol, with a number "5". LDPE should have a number "4" in the triangle. Neither of these are the BPA containing plastics, which are being blamed for health problems (those are 3, 6, and 7).
    Teflon.... -> 2.0
    Aerogel.... probably slightly above 1.00..?
    It is almost entirely made of air, which should have a very low DC.
    I'm not aware of any easily available for low prices.
    The Polypropylene is used in most of the hazy translucent Rubbermaid containers, and other storage containers at Walmart, etc. Look for the "5", or "PP". They would be far better to use than compressed particle board for low DC coil forms.
    Kevco
      Maybe a stupid question to you
      On the capacitance checks ie coil etc, can it be read with a capacitance meter or is there more to it.
      As you may or may not know I have a TV Radio business here in the UK, so i do have all the equipment you mention , but I mainly use it for repairs within my industrie.
      Since joining this forum im getting the bug to make and understand things.
      I got to hand it to you lot your all so clever and switched on.
        Here is How I test for Interwire Capacitance.
        The Coil MUST be Held in "FREE AIR". (Suspended by a String)
        Not just laying on a bench.
          Here is a link that Reg had provided, that you can compare capacitance between two similar wires: http://www.mogami-wire.co.jp/e/cad/electrical.html
          And a simple circuit to measure inductance:
          I'll use the first site to choose the wire to wind a coil. And the second site to measure the actual coil inductance.
          Kevco
