Shielding of coils
The shielding of coils is one of the most important steps in manufacturing good coils.
There is various ways and materials used in this process.
This is a short list of some compatible materials for shielding coils;
Aluminium foil, Copper foil, Nickel Screening compound, Graphite paint, Electrostatic (conductive) plastic foil, Flat aluminium or copper wire, drain wire.
The main problem when shielding coils which will always occure is the offset valtage in the receive coil of the system, caused by this screen (shield).
The different materials used for shielding are causing change of the phase alignment between the TX and RX coils, which results in lower efficiency of the system. The best efficiency for two coils in induction balance will be acheiveble without any shielding, but unfortunately that arrangement will not work in real conditions. Now, from this follows that the shielding should be as less notiseble factor in the balance as possible, with other words the shield should not produce any additional phase shift if it is possible or as little as possible.
From one side if the shield is not thick (high resistance) enough that will keep the over all efficiency high, but in some cases the stability of the coils to whats some capacitance factors can be compromised. From the other hand if the screen is thick (low resistance, for example 50 - 100 microns of aluminium foil) that will get the system very stable regarding the capacitance between the ground and the coils, but the over all efficiency will be less compared with unshielded coils.
It is not difficult to conclude that some compromise has to be acheived, which will depend on the design specifications.
My pesonal preferance falls on the aluminium foil as beeng one of the easyest and most relieble to use.
One very important factor when shielding. THE SHIELD OF ALL COILS SHOULD NOT BE MADE AS CLOSE ( SHORT ) CURRENT CIRCUIT. LEAVE SOME SMALL GAP ANYWHERE ON THE COIL WHICH WILL RESULT IN THE SCREEN WITH WIRE CHARACTERISTICS, NOT RING. CLOSED RING SHIELD WILL DEMOLISH COMLETELY ANY EFFICIENCY OF THE COIL SYSTEM, BY PRESENTING VERY HIGH LOAD TO BOTH COILS. THIS CONDITION IS VALID IN CASE OF ALL MATERIALS USED FOR SHIELDING.
Another important condition is that the shield of the two loops should be elecricaly isolated from each other over the perimeter of the coils and conected only trough the drain wire which goes (in most cases) to the ground of the power supply.
Please clerify what do you call X demodulator`s loop?
