Originally posted by chemelec
For my GoldDetector-PI i consider the pulse-delay in relation to inductance.
The better coil i made, 350 uH, can be "sampled" at 9 uS with a TX of 80 uS (5A used).
Can you test this TeslaCoil with similar conditions? I need to compare the decay fly-back for ther 2 coils
single spiral coil = high Q Factor,
Tesla... lower Q an lower self resonance.
Can you post the decay picture for the single and tesla coil with the same division unit on your scope? This help us to see the exact sample point (you can mark with some img-editor).
i made 3 good-on-air spiral coils and never used on field,
to much weight,
to much capacitance on ground exposition,
absence of shield...
I never resolve those problems, i go back to "eric foster-like coil"
Oddly, it's the fastest and deepest experimental coil I've made so far! (which may of course mean absolutely nothing!).
I had to demagnetise the nails before using this rig - there was a strong pull from both without any current flowing. Again the null is obtained when the electromagnets are equidistant from the compass. A few less turns but a greater flux than before but still the same result - the myth is still busted!
