Originally posted by Op04
Damping dilemma
Originally posted by lucifer View Post
Target stimulation does not depend on the flyback voltage. It depends on the current through the coil and how quickly it changes. Peak current through the coil doesn't really change with different values of damping resistor. Higher value damping resistor makes it possible to better detect targets with lower conductivity (including gold). A too low value of the damping resistor will make your detector find only ferrous objects.
Originally posted by Op04 View Post
I'm talking about the energy saved and spill out back from coil after turn off, yes I forgot to mention how fast it changing.
Right, a low value damping resistor will make the coil current discharge slower. It's better to discharge the coil as quickly as possible.
As a consequence, in order to maximize the response, the discharge needs to last for at least 3 target taus. This time and the rate of discharge determines the peak current at the Tx coil.
For example, at a discharge rate of 1A/us maximizing the response of a target with a tau of 4usec requires 3 x 4 = 12 us. Maintaining said discharge rate for 12usec would require a peak current of 1 A/us x 12 us = 12 A.
But if you're looking for low conductivity targets, say tau = 1us then your peak current would be 1A/us x 3us = 3A.
So depending on your maximum available peak current and the targets of your interest, it might be better to apply a slower discharge rate for a longer time than a faster rate for a shorter time.
Lots of compromise to be made.
The coil's rate of current discharge dI/dt determines the EMF induced in the target. The EMF generates a current in the target that takes three target time constants (tau) to reach 90% of its maximum possible value.
See this post for diagrams.
- Likes 1
Isn't the damping resistor also acting to discharge the coil? Wouldn't a lower resistance discharge it faster?
Make sure that your damping resistor is not getting too hot as it’s value tends to drift higher in resistance value due to the heat.
Joseph J. Rogowski
Thanks Carl and Joeseph.
I was confounded why my Tektronix analog scope wasn't showing the waveform I see in videos about damping (10x probe).
While I was away from the forum, I was doing some more reading and testing.
I remembered I have a little pocket digital scope I bought about 5 years ago so I tried it on the coil (10x probe).
First pic is the waveform without any damping. I'm not sure why it doesn't show the ringing that my Tektronix scope does.
Second is the waveform with damping adjusted so the waveform is flat with the grid line. That is what we want to see right?
Over damp and the waveform dips under the grid line then comes back up.
If I add the shield and measure with the digital scope, the variable damping resistor has no effect on the waveform. (Scratching my head over that one.)
A 600 Ohm resistance gives me the waveform you see in pic #2. The coil with shield works nicely down to 10us on the TDI.
I am going to try adding a little more resistance to the damping (slightly under damped per your recommendation Carl) and see how the coil performs.
However I am encouraged with the improvement I see in the coil performance.
- Likes 1
