Originally posted by Carl
If we as a collective group could derive how to use 300 ohm TV cable or a similar cable to replace a typical coax with about 100 pf of capacitance, we could find a new way to make faster coils. The main challenges are as follows.
1. Minimizing EMI and other noise pickup using this type of 300 Ohm wire.
2. Allowing the coil metal shaft length to be adjusted with the wire inside.
3. Finding a creative way to bring this new design into the control box to connect to the circuit board.
4. Find a new way to bring the coil wire leads out of the shell and up the plastic stem to make the connection to the 300 Ohm wire where the plastic stem meets the metal adjustable shaft.
5. Find a creative way to shield the coil wires going up the plastic stem using Scotch 24 wire mesh.
6. Use low dielectric foam to suspend the wire within the metal shaft.
With all the creative minds on this forum, this could happen!
Joseph J. Rogowski
