1x1meter coil for delta
  • 1x1meter coil for delta
    hi master.. hope you are always healthy. I want to make a delta sniffer coil with an induction of 300-320 uH and a coil diameter of 1x1 meter. I saw on YouTube this type of coil uses a cable. what cable should I use and how many pairs of cables. Thank You
    i must not write be cause i have so much posts here and english is not my native.
    just photos. Click image for larger version
ID:	410652 Click image for larger version
ID:	410653 Click image for larger version
ID:	410654 Click image for larger version
ID:	410655 Click image for larger version
ID:	410656 Click image for larger version
ID:	410657 Click image for larger version
      ohms ?how many you say ?for the 1x1?
        i must not write be cause i have so much posts here and English is not my native.
        just photos.]
        I think you should write... your English may not be good, but your knowledge is important to us... everyone will respect you... well they should
        but your choice
          hello from Greece my frends .
          use or ftp cable but the best for me it is emaye coil cable for snifer or delta p. you need 7 or 8 for deep searching but please how many ohms is my question for 45x45cm or 50x50 cm cyrcle big coils for these 2 how many ohms we must make it? thankou
            I would not worry too much about the resistance. Try to use 18-20 awg (1.0 - 0.8 mm) wire and you will probably end up with 1-2 ohms. That should work.
              if that can help
                yes, this is the photo of the coil that I want to make
                  2ohm, coil 24cm. Mybe same.
                    thankoy very much Bayu .
                    can i ask because it is importand to me ? i have 1 coil cover 45cm x 45 cm how much ohms and mh with 8mm coil cable should i ,do it for be perfect at all???? and depth and stability and all
