Does anyone know the pinout for the whites coin master coil or the layout on the RX and TX devices ?
whites coin master probe plug
Hi Altra ! If those are the inductances you mentioned, my inductance instrument gives a very slightly higher inductance rx 13.40uh and tx 590uh maybe my inductance device is a little wrong, but that's it ..Thank you Altra and also Karl!Originally posted by Altra View PostHi Orbit,
When Carl mentioned the Coinmaster/Prizm coil is the same.. I had a prizm years ago and measured the coil
Rx = 13.25mH 15 ohm
Tx = 512uH 1.5 ohm
The 5 pin connections are the same as above. The cable is dual coax, like s-video
Those are good values you have. Every inductance meter reads a little different.Originally posted by Orbit View Post
