minelab gpx coil design
  • minelab gpx coil design
    im new to coil making so am a little confused ! the only pin diagram i can fine for a mono coil has 2 pins tied together and the other 3 together . is there only a single coil or are the transmit and receive coils somehow tied together
    The mono coil only has one winding. The DD coil has two windings and the pins are not tied together.
      thanks Carl . back to the drawing board . maybe 2 central coils but wired double d
          Thanks everyone for your help next question .Does anyone know the induction level i should aim for in a basic mono coil
            Which detector are you using ? The best coil largely depends on the type of detector and how you intend to use it.
              GPX 5000
                L = 300uH
                R < 1 ohm
                  Thanks a lot now i have the numbers i need to use a coil calculator and i can get designing
