Eric Foster coil cable
  • Eric Foster coil cable
    Someone knows where to purchase this kind of orange cable that Eric Foster used in his coils? Thanks.
    ​​ Click image for larger version
    http://www.daxx.info/video_cables_ru/v53-v54.htm
        Thank you!
          I've seen this cable and it looks quite interesting. It has very low capacitance and could be suitable for PI detectors. The specifications are in the link. Let's see what the experts think about this cable.
          https://www.sommercable.com/en-gb/In...black/300-0091
          Technical Data:
          - Article number: 300-0091
          - Name: SC-SPIRIT LLX "LOW LOSS"
          - EAN: 4049371220248
          - Properties: OFC oxygen free copper
          - Properties: Analog
          - Application area: Stage / live
          - Application area: Mobile outdoor / indoor
          - Application area: Studio / Broadcast
          - Application area: Installation
          - Application: Instrument Cable
          - Colour: black
          - Signal transmission: asymmetrical
          - Construction: LI2Y(LS)CY 1x0,38mm²
          - Jacket material: PVC
          - Jacket Ø: 7,40 mm
          - Jacket Ø: 0.2913 "
          - Number of Channels (audio): 1
          - Inner conductor: 1
          - Inner conductor (audio): 1
          - Inner conductor (audio): 0,38 mm²
          - Inner conductor (audio): 0.0006 sqin
          - Inner conductor Ø (audio): 0,70 mm
          - Inner conductor Ø (audio): 0.0276 "
          - AWG (audio): 21
          - Shielding: Copper braided shielding + semiconductor
          - Shielding factor: 100 %
          - Copper strands (audio): 19
          - Copper strand Ø (audio): 0,16 mm
          - Copper strand Ø (audio): 0.0063 "
          - Conductor insulation material: Foam / Skin-PVC
          - Weight per 1 m: 62,2 g
          - Weight at 1000 ft.: 41.8554 lbs
          - UV resistance: high
          - Fire load per m: 0,26 kWh
          - Style variant: round
          - Packing: 100 m
          - Temperature min.: -30 °C
          - Temperature max.: 70 °C
          - Width: 7,4 mm
          - Width: 0.2913 "
          - Height: 7,4 mm
          - Height: 0.2913 "
          - Capac. cond./shield. per 1 m (audio): 57 pF
          - Capacity wire/electic screen at 1 ft. (audio): 17.3736 pF
          - Insulation resist. per 1 km: 1 GΩ
          - Insulation resist. per 1000 feet: 0.3048 GΩ
          - Insulation resist. per 1 km (audio): 1 GΩ
          - Insulation resist. per 1000 feet (audio): 0.3048 GΩ
          - Conductor resistance per 1 km: 48 Ω
          - Conductor resistance per 1000 ft.: 14.6304 Ω
          - BPVo-Euroclass: Fca
            Originally posted by cristiano.sar View Post
            Thank you!
            welcome
              That black sleeve inside copper mesh I remember Eric Foster say something not good about it
