seems now happy !
Hi Leto and all,
I'd like to send many thanks to everyone for the useful help and for every hint.
Endly I've rewounded Rx and obtained a good null at less than 1mV peak to peak.
I found also a problem on PCB that was almost invisible without using a lens !
Was a little short due to a small solder metallic "ball" that was "glued" by flux
accross two pads...I've already washed out the excess of flux by a solvent...but
this little thing there was, as I say, almost invisible and impossible to find if
I wouldn't followed signall path using the scope, discovering the "little" mistake.
I have again 33078s as low noise op amps, not yet 33178s.
Much consumption BUT
Now, in ALL METAL wow ! it works fine...pretty good:
2 eur coin at 28cm ---> small output volume boost that is easy to ear in headphones
Like in other VLFs different alloys responds very different here...but:
- a small gold ring (1.5 grams) at 24cm that seems very good considering low tx power!
My coil is now very well nulled, and my actual "recipe" is:
104 turns for TX on 200mm id
155 turns for RX on 120mm id
25 and 3/4 turns for RX1 (0.25 of turn 26 shaped in the middle between tx and rx) 200mm id
(with my components is OK)
very good ! on TX osc I have (as in Mike's "recipe"):
- TX coil gives 10.022 KHz
- RX+Rx1 coils gives 10.506 KHz
- whole RX+RX1 nulled signal on 1Kohm load and 47nf cap is less than 1mVpp
Needs very good shielding too...I haven't at now on and capacitive is a huge problem.
All the stuff run in "motion" mode ...why the manual talk about non-motion ? where is it ?
Only disc doesn't work well till now...about 1/3 of all metal performances...no good!
Have to fix it, somehow...
Best regards,
Max
Originally posted by Leto
Best regards,
Max
PCBs are in Eagle program and all the documentation in .rar compressed files. You can compare with all has been done by you at this moment. Remember that the second TX coil is winding in reverse, so big TX and receiver are in the same orientation winding and secondary TX (bucking coil) is in reverse winding (or phase).
, then look for the problem. Yes the IC7b is a phase shift (how else to work the discrimination ????)
