Hi all,
after making 5 test case models, it showed, that I have to add the wire diameter w used in the bundle coil. With parameter a and w the compactness of the bundle coil is described.
It is generally possible to find a good approximation formula for single loop turn coil emulation.
But 5 test cases are not enough. I also have to make different coil shape models. Different sizes, different compactness, .. it goes into dozens of test cases...
This is the approximation formula for 5 test cases I made. The AI can find the best approximation formula.
d, a, R, w: units mm
Nice.
Nice.
